Question about Goodman Heating & Cooling
Pvp pipe from drip pan is not draining what can i do
  • 828 Answers
If the water is backing up clean out the drain line or replace it. Code requires a trap and traps catch dirt and plug. Would be nice if they put a clean out on these but it does not always happen.
Posted on May 27, 2008
Disconnected condensation drain on hot water heater.
Tankless or hybrid water heater?
Tankless gas must have special fitting between water heater and vent that has a condensate line fitting. Hot toxic vent gasses traveling up vent pipe cause acidic water vapor to form inside vent pipe that drips back down vent and drips onto heat exchanger and other parts eventually burning hole through expensive metal alloy heat exchanger, rendering tankless computer water heater useless after electric circuitry gets wet and shorts out.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#vent
Hybrid or heat pump type computer water heaters must have condensate drain connected to catch pan located just above storage tank and below compressor. Condensation can form on condenser coils and drip into catch pan where there is primary and secondary drain
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
Read product manual
Gene
h
Apr 17, 2014 | Water Heaters
Drip pan full of water
Hi, in a typical set up the coil pan itself which is located in the air handler has a pan, it should have a drain pipe connected to it, usually a 3/4" PVC pipe ( white but sometimes black ) , that is the primary drain, the pan that is under the entire unit which I believe is what we are talking about being full of water is the secondary pan, that one should have no water in it. Let me know if you see this other drain pipe,
Jul 22, 2012 | Maytag Neptune MAH5500B Front Load Washer
During the defrost cycle our refrigerator leaks water from the freezer side out the front into the floor of the kitchen. Where could it be coming out and what will fix it?
The water from the melting ice during defrost should be guthered from the drip drain pan which is under the evaporator pipe coil and is passing though the drain tube which is conected to the dip pan and should end out on the back of the fridge to the compressor to evaporate. The problem posibly is that the drain tube is goggle either from ice or from dirt or both and the water since it can not end to compressor it overfrow from drip pan inside the freezer. So you can clean the drip pan and drain tube using a wire rod and problem will be solved.
Sep 13, 2011 | Refrigerators
My ac unit is now after 3 weeks of use dripping water inwards(even with a 1/4" slope of the unit to the outside) is my drip pan overflowing?
Yes, your drip pan is overflowing, because the drain hole near the back of the unit is clogged. There are 2 ways to address this problem.
1. Look out side the house, under the unit and search carefully for the drain hole or drain tube. If it's a hole, clear it using something like a pipe leaner. It it's a tube, use 2 pipe cleaners twisted horizontally together and carefully run it up into the tubing in a push/pull motion. This will help dislodge any clogs.
2. If you're feeling really lucky, turn the unit OFF and unplug it. Straighten out a wire coat hanger leaving a little hook on one end. Remove the front cover of the AC unit and slide the coat hanger under all the mechanical parts into the drip pan. Sweep it around carefully in the drip pan. all the way to the back of the unit. Be careful not to get the little hooked end caught on anything, by keeping it flat against the drip pan. Doing this, may dislodge any clogs.
And finally, if you're in a high humidity area, increasing the tilt to 1/2" may help improve the drainage.
Hope this helps you unclog the problem.
Jul 20, 2011 | Heating & Cooling
We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air...
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Sep 14, 2010 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
DRIP PAN IS CLOGED NEED TO LOCATE TO UN CLOG
The drip pan is located at the bottom front.. Pull the bottom cover off and you will find it there..
Have a great day
Sep 25, 2009 | GE GSS25LGM Side by Side Refrigerator
My Daewoo DSB 091L unit has started to drip condensate from the casing joint underneath the front drainage tray. I have cleaned the blocked drain pipe and proved the water drains away. The condensate drip...
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Mar 24, 2009 | Heating & Cooling
Hi, I have water dripping from my a/c, on the inside
The condensate drain line is probably clogged.
Find out where the pipe exits the home, and attatch a wet/dry shop vack to the end of the drain line, close it up around the pipe as much as possible and trun it on.
These typically get clogged with dust, dirt, pet hair, mold etc.
They usually clog at the elbows, P-traps and the inlet coming from the drain pan. There is an internal drain pan in the unit that catches the condensation. When the line clogs the pan overflows and you have water dripping from the unit.
There is also a small chace the pan has a hole in it, but thats fairly rare. There is also a chjance that if the unit is not level the water will overflow the pan before it can drain. (most pans are only 1 to 2 inches deep.) Make sure the unit is level or veryslightly lower toward the drain side.
Dec 09, 2008 | Heating & Cooling
Drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Nov 29, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Heating & Cooling Logo
64 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
