Question about Kenmore Refrigerators
Compresser runs but doesent get cold - Kenmore Refrigerators
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 04, 2010
1999 DODGE DIESEL WONT START ON FIRST TRY TURN KEY OFF AND TRY AGAIN AND IT FIRES RITE UP AND RUNS FINE DOESENT MATTER IF ITS HOT OR COLD
Check voltage at starter (small wire) then check starter contacts..remove starter and take it apart. If they look chewed up replaace them.
Had the same problem and found burned contacts in 97 Diesel.
Feb 17, 2013 | Dodge Ram 3500 Cars & Trucks
Hp dv6-6120us problem with finger print reader after formating doesent work any more
try and download the exact drivers from ho official site,and run these set of hardware drivers you are having problems with....i hope this will be of help to you,,...bye ya
Feb 09, 2013 | Dell F3534 Touchpad
Homelite c-51 wont start
I would first clean fuel tank with carb. Cleaner and compressed air then check all fuel lines as they will probably need replaced, clean all gunk from carb with carb. Cleaner and compressed air, check muffler for dirt dobber nest etc. and then start.
Oct 01, 2017 | Garden
Nail doesent come out all the way,half in board half still in gun,happens about every 5th nail
air presure droping on you try on a bigger compresser and oil up air intake should help
Jul 13, 2011 | Stanley Bostitch N66c1 114"to 212" Coil...
Fridge works , but it doesent get cold. how can it be fixed
The condenser could be shot or it could also be the freon/ refridgerent used to make it cold. Check the back of the unit out...
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
The hot and cold selector switch on the heater doesent function
That part of the needs to come apart to see what is wrong.
Apr 10, 2010 | 2004 Ford Explorer
My A/C in my jeep wrangler doesent blow cold i had it recharged and it worked for a couple of days but stoped after that what could it be
sounds like you have a freon leak. you will need to have someone put dye in the system and then run it and see if they can find it leaking.
Feb 16, 2010 | 2001 Jeep Wrangler
Recently, my temerature gauge has be going up and down. About 2 weeks ago, put in coolant. Car took 1/2 a bottle. Ran fine. Now temperature going up and down again. Concerned it is going to overheat. What...
Try taking out the thermostat and putting in a cup of hot water then see how fast it opens ,then in cup of warm water and check again then add hot slowley and if doesent open and more get a new one.
Also check the Radiator after running when temp is almost at usual working temp and turn engine off and now check radiator by putting your hand flat on the core all over and if you have hot and cold spots then the radiator could be bunged up or dirty inside and out side in the fins(use garage compressor to blow out dust),
If still gets hot check to see if you are loosing coolant if so have the engine checked A Compression test as you might have compression getting into the water system due to head gasket ,but check all above first.
Let me know how you get on ... RON
Nov 18, 2009 | 2001 Chrysler Sebring
I got a 1988 mercury grand marquis LS that just about stalls when you drive it cold and put it into park. Cold meaning the oil is cold not the weather.
it doesent mean the weather it works the same if the engine hasent been rann for awhile its not at operating temp try running it till it reaches normal temp if it does not stall its your cold oxigen sensor
Sep 30, 2009 | 1988 Mercury Grand Marquis
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
