Question about Panasonic SC-AK600 CD Shelf System
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Posted on Dec 18, 2010
Need manual & remote
You can try www.panasonic.com contact customer support, or go to www.ebay.com Type make and model and go through the possible list if available.
Jul 19, 2012 | Panasonic SC-AK600 CD Shelf System
I have a stereo system, sa-ak 78, it wont store and change 5 cds. Think a part is broken, but cant figure which part?
The pladder may not be turning, remove top, and remove clip, now carefully pull pladder off, make a note of the position it go's back in, this will expose some of the key parts.
Mar 17, 2012 | Panasonic SC-AK600 CD Shelf System
Panasonic SC-AK600 CD player says "no disc" when
Your cd laser lens has got weak.get it replaced.
you can replace only the lens or the whole laser pickup.
Dec 29, 2010 | Panasonic SC-AK600 CD Shelf System
I HAVE AN OLD SA-SK600 CD PLAYER WITH 5 CD CHANGER AND 5 SPEAKRS I LOST THE REMOTE CONTROL FOR THIS SYSTEM HOW CAN LET THE OTHER SMALL SPEAKERS WORKS UNTIL I FIND OTHER REMOTE CONTROL
the only way is to use dolby pro logic mode but you can not set the volume of centre and surround speakers individually now,for that you need a remote.
Dec 13, 2010 | Panasonic SC-AK600 CD Shelf System
My panasonic cd stereo system SC-AK600 keeps telling me that there is no disc even though all five disc trays are loaded, what is wrong with it
sounds like the laser is no longer working. Call partstore at www.partstore.com and let them know what model number you have and that you are looking for a replacement laser for the unit. Replacement is for the mechanically inclined or a technician. The part is static sensitive so I recommend taking the unit to a repair center.
Jan 01, 2010 | Panasonic SC-AK600 CD Shelf System
Do not have manual for panasonic SA PM53 CD player & I need help
You can download the required manual by clicking this link
Hope this solves your problem. Thanks.
Oct 20, 2009 | Technics SA-AX530 Receiver
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Panasonic sa-pm21 sterio cd
The outputs on this unit are defective. This unit requires service. This is a very common model and teh repair should not be too expensive. Figure between $15 and $40 for parts plus the local labor rate.
Dan
Mar 25, 2008 | Audio Players & Recorders
Nide code fore a panasonic cd stereo sistem
Most likely the regulator IC is defective. Part # C5BA00000105.
Jan 15, 2008 | Panasonic SC-AK600 CD Shelf System
Locked sa-ht67
I hope you've already unlocked your DVD player by now, but for all those searching after you, I got the solution from Panasonic.
Make sure the device is on the DVD/CD mode. Press the Stop button on the main unit and the >=10/Enter button on the remote control simultaneously. You will see the word "Initilize" on the device, and at that point it is unlocked.
Dec 11, 2007 | Panasonic SC-HT67 System
Panasonic SC-AK600 CD Shelf System Logo
370 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
