Question about ADVANTAGE Sportline 340 Walking Advantage Pedometer
My dad gave me a sportline 340 walking advantage pedometer but lost the instructions. I would like the manuel so I can set it to my stride and know how to use this. Where can I get the instruction manuel?
  • 8,197 Answers
You can get the manual on the link below.
http://www.sportline.com/manuals/340.pdf
Good Luck and please rate 4 thumbs up and please leave a testimonial
Posted on Oct 04, 2010
Lost my instruction manual fors my pedometer 347 sportline
Go to the product website itself look for a down loadable and printable verision for the product,if the product it still in the selling market.If not look in the website for their customers services phone numbers,give them a call and pay them a fee they'll send it out to u.
Oct 28, 2011 | Sportline Walking Advantage 347 Speed...
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I have the most simple sportline pedometer. I want to change it from Km to miles...can't figure it out and have lost the instructions.
Hit he Mode Button until you reach the Distance Mode (MIL or KM) will appear on the display. Press and hold the Reset Button (S) until the display changes to the mode you want. Note that performing this step will reset all your readings to zero and return your stride and weight setting to the factory settings.
Manual here: http://www.sportline.com/manuals/303.pdf
Jan 01, 2011 | Sportline Exercise & Fitness
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
Aug 07, 2009 | Sportline 345 Electronic Pedometer
Pedometer # 4202
The Sportline 4202 has three buttons, Top MODE, Right S/R (RESUME/STOP), Left SET.
MODE - press once to alternate between Steps (how many steps you taken) and Miles (how many miles walked).
S/R - Clears the count to 0 for any mode by pressing one second. To change from Kilometers to Miles or Back Press S/R for 6 seconds.
R/S press one sec and then press SET one second to set "goals" for both steps and miles.
To change length of stride: press the buttons one at a time in the following order- R/S-SET-MODE.
It may take several attempt to get into the set stride and it may take you into other menus such as Goals in the process, just keep going in circles until you get to stride and change length with R/S and set with SET.
Feb 22, 2009 | Sportline 345 Electronic Pedometer
ADVANTAGE Sportline 340 Walking Advantage Pedometer Logo
718 people viewed this question
Top ADVANTAGE Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an ADVANTAGE Exercise and Fitnes Expert? Answer questions, earn points and help others
