Question about BMW 3-SERIES CONVERTIBLE
ELECTRIC ROOF OF MY E36 IS NOT WORKING. HAVE CHECKED THE FUSES AND ARE OK.
    Sergeant:
  • 168 Answers
Its possible that you have any dirty in the internal or any wire broke.
Check it and tell us news.
Posted on Oct 04, 2010
Cabrio power windows front and roof not working
there almost certainly is a relay involved with the roof system and windows ,what year is vehicle so can find a wiring diagram ?
Apr 14, 2014 | Volkswagen GT Cars & Trucks
My CRX roof wont go up and down with the switch on the dash, yet the boot lid goes up with the key, cheecked fuses ok, cheecked plug and control box fault LED flashed seven times and then later on flashed...
7 blinks (roof lock switch,not operated by user)
9 blinks (rear window switch not operated by user)
These codes mean user has not undone roof locks or rear window is not fully closed
Providing that is not your problem,reset roof control unit
Turn ignition off
In under bonnet fuse box remove fuse 32 7.5 amp for 20 seconds
Refit fuse and check roof operation
This clears codes and resets roof
Apr 11, 2010 | Honda del Sol Cars & Trucks
Electric windows and sun roof in my p reg VW polo are not working
pls. check the relay or fuse that controls the motor function of ur sliding roof and window/ if relay and fuse is ok? check the electrical supply if ok then the motor is fried....
Apr 09, 2010 | Volkswagen CC Cars & Trucks
The windows and sun roof doesnt work i think i have a blown fuse
The fuse and relay box on the E30 and E36 models is located in the engine compartment. The E36 models also has relay boxes located under the left side of the dashboard.
Circuit Breakers
Resetting & Replacement
Circuit breakers are located inside the fuse panel. They are automatically reset when the problem corrects itself, is repaired, or the circuit cools down to allow operation again.
One of the less known about fuses that can cause all this to go out is the fuseable link. It is in a black plastic box near the battery. It is an appx 60A thin metal strip fuse. Check the website link to the right for more info.
Also, I suggest check your Fuse Diagram in the BMW 525i Owners Manual here.
Power Sunroof
Emergency Closure Operation
The sunroof is equipped with an emergency closure feature should the sunroof motor fail or the vehicle has lost electrical power. To close the sunroof under these conditions:
  1. Remove the front headliner trim panel.
  2. Using the 6mm hex key that is included with the tool kit, insert the key into the hex socket and turn the socket to close the sunroof.
Fig. Remove the trim panel to access the sunroof motor
Fig. Insert the 6mm hex tool from the tool kit and turn the hex socket to close the sunroof
Removal & Installation
E30 Models
Fig. Sunroof components-E30 3 Series shown, E36 similar
Fig. Sunroof lid retainer clip location-E30 3 Series shown, E36 similar
  1. Open the sunroof lid 2-4 inches (5-10cm).
  2. Unclip the roof liner frame and push back into the opening.
  3. Close the sunroof lid and loosen the screws on each end of the gates.
  4. Pull in the retainers, remove the center screws and lift off the lid.
  5. Remove the cover over the motor and gearbox. Close the sunroof lid, if not already closed.
  6. Disconnect the wiring harness and remove the 3 mounting screws. Remove the motor and gearbox.
  7. Push the cables back evenly on both sides. Remove the rail covers and pull the cables out of the guides.
  8. Place the cable in the center position of the gate and press off.
To install:
  1. Install the cables to the gate. The cable are marked with the proper side of installation. Do not lubricate fabric covered cables.
  2. Pull the cables through guides and align the cables. Insert a hex key through the gate and cable at the 0 position.
  3. Install the motor and gearbox. The motor and gearbox must be synchronized with the hole in the drivegear aligned between the centers of the 2 gears. Torque the bolts to 2.0 ft. lbs. (2.8 Nm).
  4. Install the sunroof lid. Use new screws and torque to 2.5 ft. lbs. (3.5 Nm).
  5. Adjust the sunroof lid. Pull the roof liner frame into position and clip into place.
E36 Models
  1. Close the sunroof fully. With a quick actuation of the sunroof opening button, open the sunroof so the back edge of the lid depresses 0.08-0.12 inches (2-3mm).
  2. Slowly push the roof liner panel back into the roof. Do not force or use a quick motion or damage could occur.
  3. Remove the mounting screws and pull the lid off at the rear side. Do not operate the sunroof with the panel removed.
To install:
  1. Install the lid and check that the hooks and levers align. Install the screws with threadlocker or use new micro-encapsulated screws. Torque to 2.5 ft. lbs. (3.5 Nm).
  2. Adjust the sunroof lid. Lower the rear of the lid by operating the motor. Pull the liner forward and clip into place.
Good luck.
Mar 15, 2010 | BMW 525 Cars & Trucks
Problem with convertable roof
Check the cable to see if it's not broken
Aug 11, 2009 | 1988 BMW M3
1996 BMW E36 Convertible to stopped working.
Change switch first checking all contacts(wires to clips)
Jun 25, 2009 | BMW 318 Cars & Trucks
1999 bmw 328i convertible trunk will not open with button or key what do I do
UPDATE: I thought I was posting regarding a 1998 E36. Not sure a 99 has the same fuse or interlock.
Jun 24, 2009 | 1999 BMW 328 Series
Volvo 2003 s60 sun roof do not open, fuse ok.
check your fuse in position 38 in the fuse box....this fuse is for the car's alarm system but also seems to work the sunroof, I have a problem with this fuse when its not blown the sunroof opens with no problems but when it blows the roof will not open I am not sure how they are tied in together but they are....so I would say that you have an electrical issue....do not replace the motor until you check this first
Jun 05, 2009 | 2003 Volvo S60
Indicator/turn signal problem on a 96 mercedes e36 amg
hi,seem you have a bad connection on wiring,advice to visual check,open your hood check the wiring if there is trace of rat bite,in area of control module,ty
Mar 30, 2009 | 2001 Mercedes-Benz E-Class
Climate control bmw e36
http://www.macadamizer.com/bmwfix.html
Feb 10, 2009 | 1997 BMW 328
BMW 3-SERIES CONVERTIBLE Logo
285 people viewed this question
Top BMW Toys Experts
Andrew Taylor
Andrew Taylor
Are you a BMW Toy Expert? Answer questions, earn points and help others
