Question about Mitsubishi Computers & Internet
Hi I need a power cable for Diamond Digital monitor DV175. rating 12 V , 3.33 A 40Watts max Note : it has a single pin that goes into the monitor.
  • 11,361 Answers
Widetech the max psu update, now black screen on monitor
Kind of hard to give you a cable diagram, Roslyn, when you haven't stated what motherboard manufacturer and model number.
Or computer manufacturer and model number.
(Back of computer next to Windows product key; or up on side of computer tower )
So we'll wing it..............
Widetech the Max. A modular line of Power Supplies.
1) Main power cable;
It will be either a 20-pin ATX main power cable, or a 24-pin ATX main power cable.
The WTM (Widetech the Max) will have a braided thick cable, that will have a 20-pin connector, and a 4-pin connector.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
The 20-pin connector, and the 4-pin connector, should have a white arrow on the side. The arrows point to each other, when the two connectors are properly aligned with each other.
So, ATX main power cable plugs into Power Supply, (If removable), and 20 + 4-pin connector plugs into motherboard.
When the hooked end of the Lock, on the side of the power cable's connector; is over the Tab on the motherboard connector; the power cable is deemed to be plugged in properly, and tightly.
Note*
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
Black wires are Ground wires. (Also are Negative)
Note that the extra 4-pin power cable, that attaches with the 20-pin ATX power cable; has TWO Yellow wires, a Red wire, and a Black wire.
This way you don't accidentally somehow, plug the following power cable, in with the 20-pin ATX main power cable,
2) 4-pin ATX +12 Volt power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
When Processors started using more power, than just the processor socket (Motherboard) could deliver, this power cable was brought out to help carry the load.
Note*
TWO Yellow 12 volt wires, and TWO Black ground wires.
3) 8-pin EPS +12 Volt power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
Brought out for motherboards supporting multiple Processors, (CPU's), such as a server computer; but with processors needing more, and more power; is used quite frequently by motherboard manufacturers now.
NOTICE the power wires. The color code of the insulation of the wires.
FOUR Yellow wires (12 Volt), and FOUR Black wires. (Ground)
NOT to be mixed up with the following power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
This baby plugs into a GRAPHICS CARD (Video Card. Same/same)
A PCI Express graphics card, IF it uses one.
The PCI-Express x16 slot on the motherboard, is only capable of delivering 75 Watts.
This power cable can deliver UP TO an additional 150 Watts.
It is an upgrade of this power cable,
The 6-pin PCI Express power cable was brought out, to provide more power for a graphics card.
75 Watts.
So now you have the PCI-Express x16 slot on the motherboard capable of 75 Watts, and the 6-pin PCI Express power cable capable of 75 Watts; for a total of 150 Watts available for a graphics card.
PCI-Express x16 slot on motherboard, and 8-pin PCI Express power cable?
225 Watts.
This power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
Is for a motherboard that uses a 4-pin ATX +12 Volt power cable, OR an 8-pin EPS +12 Volt power cable.
Is a combined power cable if needed, just like the 20 + 4-pin ATX main power cable.
This power cable is a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Used to plug into a Harddrive, or Optical Drive. (CD/DVD drive)
NOTE*
IF your SATA harddrive has a provision on the back; to plug in EITHER a SATA power cable, AND a 4-pin Peripheral power cable; ONLY use the SATA power cable.
Using BOTH power cables will burn up the harddrive. May not happen immediately, but I ASSURE you it will happen.
4-pin Peripheral power cable, is also erroneously known as a 'Molex' power cable.
Molex was the first company with the CONNECTOR design. The name stuck. Kind of like calling an adjustable open-end wrench, a Crescent wrench,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
[ IDE (PATA) harddrive shown in photo. Not a SATA harddrive ]
Note that between a SATA power cable, and a SATA data cable; the SATA power cable's connector is longer.
SATA power cable connector has 15-pins.
SATA data cable's connector has 7-pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening of the SATA data cable's connector; and the L-shape of the motherboard connector.
The SATA power cable has the same L-shaped opening.
NOTE that color of connectors does NOT matter.
Could be green with pink polka dots.
It is the wire color code, and connector SHAPE, that matters.
[Applies to ALL cables, and connectors}
Sometimes the SATA power cable, and SATA data cable connectors; have a lock on them.
May not see it very well. It is usually a slightly raised bump on the connector. This is depressed with a thumb nail to unlock.
Unlock WHEN installing, and removing.
ALWAYS use the connector when plugging in, or unplugging a cable.
DO NOT pull on the wires.
(Even if you have to stand on your head, and whistle 'Dixie')
I lay the computer opening side UP, on a static free towel, on a table. Much easier to get to the cabling.
ONLY plug in the cables you need, to the Power Supply.
That's what Modular cabling is all about.
Gives more room when not using unnecessary cables, and more air flow through the computer case; for cooling.
I just installed a ThermalTake TR2 600 power supply. It is Modular Cabling also.
I'm willing to bet you didn't plug the Processor (CPU) power cable in.
Either a 4-pin ATX +12 Volt power cable, OR an 8-pin EPS +12 Volt power cable.
Make sure the Ram Memory is seated tightly also.
It get's bumped loose when installing a Power Supply.
No,.....you CANNOT just visually inspect, and let it go at that.
You HAVE to remove ALL ram memory modules ('Stick'), and plug them back in again; to be ASSURED that they/it are seated tightly, and correctly.
Well that about does it for me kid, post back in a Comment if you have additional questions.
Regards,
joecoolvette
Jan 01, 2013 | Computers & Internet
How can i use dvi port
DVI stands for (D)igital (V)ideo (I)nterface.
DVI is a new form of video interface technology made to maximize the quality of flat panel LCD monitors and high-end video graphics cards. It is a replacement for the P&D Plug & Display standard.
you can connect high definition monitor , LCD projector , LCD T.V to a DVI port
There three kind of DVI connector
1. DVI-D (Digital)
2. DVI-A (Analog)
3. DVI-I (Integrated Digital/Analog)
DVI-D format is used for direct digital connections between source video (namely, video cards) and digital LCD (or rare CRD) monitors
DVI-A - High-Res Analog
DVI-A format is used to carry a DVI signal to an analog display, such as a CRD monitor or and HDTV
DVI-I - The Best of Both Worlds
DVI-I format is an integrated cable which is capable of transmitting either a digital-to-digital signal or an analog-to-analog signal, but it will not work transmitting a digital-to-analog or analog-to-digital signal.
How to Recognize These three types of DVI Cable
There are two variables in every DVI connector cable, and each represents one characteristic.
The flat pin on one side denotes whether the cable is digital or analog:
A flat pin with four surrounding pins is either DVI-I or DVI-A
A flat pin alone denotes DVI-D
The pinsets vary depending on whether or not the cable is single- or dual-link:
A solid 27-pin set (rows of 8) for a dual- link cable
Two separated 9-pin sets (rows of 6) for a single-link cable
Jul 12, 2011 | Computers & Internet
How do you use external monitor facility? Aged friend has Versa m370 and needs larger screen due to poor eyesight.
does your friend laptop supports dual monitor if does you need another monitor a larger one so that your friend wont have a problem with his poor eyesight. But if it doesn't support dual or multiple monitors do the same buy a new monitor a larger one.
Jul 01, 2011 | Computers & Internet
I have a maxtor 51536h3 harddrive, I need to know the jumper settings for running single as a master and slave to transfer the data to another harddrive. THANKS
If you have two hard drives on the same IDE cable, then set one as Master and the other as slave.Set which ever one has your operating system on it as the master (though it doesn't really matter). Once you get them both plugged in and your computer boots up. You should see both drives and can transfer data as you see fit.
Mar 03, 2011 | Computers & Internet
Our computer screen will stay on for one second and then go black. Green button to signify it's on, is still showing, it simply goes black. What is happening and how can I fix it?
sir if u really love your computer, then take it to the nearest dealer. The problem is might be with the capacitors.
But my suggestion hence, is to isolate the power board (the one that has the socket for the power input), check if any of the capacitors (the tall cylindrical structures) have bulging tops, if they do, try to replace them (Novices please bear the polarity in mind when you play with capacitors) with ones with higher rated ones (especially the voltage rating, normally these would be rated for 25 volts, so try getting one that is one step higher.
Feb 27, 2010 | BenQ FP71G 17" LCD Monitor
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    Hannspree tv
    This is a very difficult question to answer without knowing more info, but here goes:
    Check the power cable, there should be only place to plug it into. This may be one of several styles depending on your model, usually a 3 prong female (just like your PC's power cable) connector, or a single pin female connector (looks male but has a hole in the center) will connect to the back of the monitor.
    If you get power, but no image: VGA connections will use a large blue connector with 15 round pins, 3 rows of 5. DVI will be a large white connector with slotted pins, with varying amounts of pins depending on the type of cable (analog, digital, or both). HDMI will be a small connector that resembles a large USB connector. You may also be using a composite or component cable, which will be color coded to the ports on the monitor.
    All styles of connectors will physically only connect to the corresponding port. Check all connections and make sure they are all secure and connected to the correct locations on the monitor. Doing this should resolve your issue.
    May 12, 2008 | Hannspree HW191D LCD Monitor
    Monitor no longer will switch to Analog (VGA) source.
    try to Lower the resolutionof your monitor.
    Mar 02, 2008 | Computers & Internet
    Computers & Internet Logo
    108 people viewed this question
    Top Mitsubishi Computers & Internet Experts
    Shaukat Bhutto
    Level 1 Expert
    Alun Cox
    Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
