The heater would not start running when it gets pluged in only when the reset swich is pressed. Once pressed it will run for about 2-3 secs. and shut off. After 5 min. or so u could try again with the same outcome.
it almost sounds like the temperature sensor is in the wrong place. that or the flow is inadequate for the heater to run. if you have a sand filter, put it on 'whirlpool' or 'recirculate' and try to run the heater.
you hold da power botton n leave it press youll here 1 beap the sec. after it will shut back down. once it shuts down let go of da power botton then 2 once again you press n hold it down youll here da 1st beep sec. after youll here 2 beeps dats when u release it n itll request you 2 plug in the usb n control aswell follow da instruction n it will direct you 2 a menu dat has options of restarting system, tile restoration, rebuild database, ect.
press reset+power for 20 seconds, then release reset ank keep pressing power, it will turn on for 10-20 secs, in this time you must connect it to the pc. run tomtom home and make the upgrades that the program sais. must help.
most of the alarm systems reset procedures are similar,lock with key/hold over for 30 secs then unlock/hold over 30 secs.(or vice versa)
OR press/hold unlock button on remote 30 secs,then press/hold lock button
OR put key in ignition,turn onto running position(not starter)and press/hold alarm button 30 secs
once car starts, it will remember codes in keys.
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
