Question about Maytag Dryers
My Maytag gas dryer (Model HYG2460AWW; Rev-10; Serial 10769745EN) is leaking something into the inside of the dryer that leaves a grey coating. The coating completely greys all of the clothing . Help!
4 Suggested Answers
  • 67 Answers
SOURCE: REPLACE BELT ON MAYTAG HYG2460AWW
Yes but there are 3 screws on the inside you have to remove also.
Posted on Aug 15, 2009
mindreader
  • 578 Answers
SOURCE: I have a gas dryer. Dryer heats up but doesn't dry
I got cut short.. and disconnected...so if this is a repeat, please forgive me:
Dryers 101
1. Heat alone does not dry clothes
2. Air alone does not dry clothes.
3. Only dry, heated air passing over and through clothes will dry them...
I recommend the following:
Set the dryer for "Air Dry".
Go outside and check the dryer exhaust.
Confirm that the exhaust is spewing out lots of air.
If it is, then you have a need for a technician to inspect everything - in person.
If it is NOT, the you need to determine the clog - or reason that air is not moving through your dryer, clothes and exhaust system.
ONLY 2 possibilities exist:
1. Fan motor is frozen and needs replacement....or
2. Duct/exhaust is clogged with lint and will not allow air to pass through.
Please check for both, clean/clear/fix as needed.
Posted on Nov 05, 2009
ilianj1
  • 67 Answers
SOURCE: I am getting black spots (short black or grey
You left something in a pocket that melted in the heat and left those spots and lines. You will need to clean the inside of the drum thoroughly. Without knowing the source of the spot and lines, I can't tell you how to remove them without damaging the clothing.
Jim Hart
Posted on Jun 14, 2010
Testimonial: "I would never have know about the seal. I will check it out and get back to you. It seems very promising though. Thanks again."
Maytag dryer burner turns off
-Possibly thermal fuse is not working properly.
Mai
Nov 11, 2013 | Maytag HYG2460AWW Gas Dryer
How to replace an Dryer Drum Belt ?
check youtube for a lot of vids on this subject
Feb 14, 2018 | Maytag Performa PAV2200
Aug 14, 2009 | Maytag Dryers
I have an LD9334 Dryer with a noise when the drum turns. One of the fins inside has a loose screw and is hitting the top as it goes around. Does the top of the dryer come up or do I have to fix from the...
I fixed mine it by opnening up the gray vent panel in the lower right corner on the rear of the dryer. By spinning the drum, I was able to loom inside with a flashlight and see the loose screws holding the loose baffle in place. I was then able to tighten it.
Jul 02, 2009 | Maytag HYG2460AWW Gas Dryer
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Maytag electric dryer mod#DE612 series02
U might want to look on the back of the dryer to see if there is a panel to take off. If not the hole top will have to come off. Is the top made on the rest of the dryer or is there a split between it.
Nov 24, 2008 | Maytag HYG2460AWW Gas Dryer
Draye heat work but not dry
check your exhaust vent hose inside and outside your hose you should have alot of air coming from the dryer to outside this is where Id start
Dec 30, 2007 | Maytag HYG2460AWW Gas Dryer
Kenmore Dryer
Unplug the dryer turn off the gas valve and remove the rear panel the motor is located below the drum
Dec 15, 2007 | Maytag HYG2460AWW Gas Dryer
Dryers Logo
26 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
