Question about Electric Intermatic 7 Day Digital Timer 500 Watt 120 Volt Heavy Duty
I have an Intermatic Model DT-17 programmable plug-in lam and appliance timer 15 amp and inductive 500 watts but no programming instructions. How can I reset the time I wish to have it turn our lights on??
  • 760 Answers
Go to www.intermatic.com Notice there is a recall for this model timer with codes 40z to 52z. Contact Intermatic for replacement. Here is link to the DT-17C probably same instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
Posted on Oct 04, 2010
How do you delete a program Intermatic hb88rc
Try removing battery, and then reprogram timer.
Some timers are reset when battery is removed.
Newer digital timers keep programs in memory when battery is removed, but in that case the instruction manual shows steps for resetting timer and deleting programs.
The HB88RC manual does not show steps for deleting programs or resetting timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Sep 21, 2011 | Intermatic HB88RC - 7-Day Programmable...
I purchased a 1875 watts Timex Heavy Duty timer Model # 12-881 to connect to my 1200 watt water distiller. The timer is burned and has melted where the distiller was plugged in. We were furtunate...
Timex 12-881 timer has 3-prong outlet and is rated 15amp 1875 watts.
The timer melted because too much amperage was drawn across the connection and timer got hot.
Different things can cause this.
Phony rating, and/or mis-manufactured timer.
Defective timer.
If distiller has a motor, then it will draw more amps at start-up.
Timer is rated for incandescent light bulbs only.
Many timers say 1875 watts resistive, but instruction sheet will show 1000Watts incandescent and 1/4 HP horsepower.
Timer is plugged into extension cord.
Cheaply built product, not meant for constant use.
Timer outlet and distiller plug did not meet firmly, so connection heated up.
Turn off distiller before plugging into outlet so no spark is at the connection point.
I recommend appliance timer for operating appliances.
For example Intermatic HB 113 timer.
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Also heavy duty portable timer like Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 01, 2011 | Timex Heavy Duty Appliance Timer
I have an Intermatic model DT 17 7day timer and I need a manuel to show me how to program it to turn on and turn off?
First some of these were recalled, see link.
https://www.intermaticstore.com/dt17recall.pgm
The instructions for a 17C should be the same.
Oct 13, 2010 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
Is the intermatic standard lamp and appliance timer..TN111C...powerful enough to start up reliably a 400 -430 watt metal halide or high pressure sodium light?? Thanks
intermatic makes a timer for window air conditioners its the same design and only a few bucks more is more robust . I just tested my 175 mh lamp and it draws 1.9 amps on start up the amps go down after it starts.. harbor freight has a cool timer also (cheap) But please try to buy the timer made in the good old USA ....Jay
Aug 20, 2010 | Intermatic TN111C Standard Lamp &...
Need instrutions for model dt-17
Intermatic dt17 timer instructions:
http://waterheatertimer.org/pdf/dt17c-timer-manual.pdf
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
May 09, 2010 | Electric Intermatic 7 Day Digital Timer...
How to set times for Model #HB88RC
I have found the instructions for your model
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
I hope that is this will help resolve your issue
Jan 14, 2010 | Intermatic HB88RC - 7-Day Programmable...
My son lost the instruction manual for our DT 500 CH self-adjusting timer made by INTERMATIC INCORPORATED, and we can't even figure out how to turn it on, let alone program it. Any help would be great!...
I Just downloaded the pdf for the same model. The link to Intermatic is http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt500ch.ashx
If that doesn't work then google Intermatic DT500CH pdf and select the return from Intermatic. It's a good timer but not intuitive. I had to look up the manual just to change from daylight savings time.
Dec 24, 2009 | RTO Intermatic DT500CL 10 Amp Indoor...
Programing
Here is a link to the instructions for easy setting your unit:
HB88RC Timer
Hope this helps!
Dec 06, 2008 | Intermatic HB88RC - 7-Day Programmable...
Electric Intermatic 7 Day Digital Timer 500 Watt 120 Volt Heavy Duty Logo
662 people viewed this question
Top Electric Hardware & Accessories Experts
pawnpower
ray gallant
Are you an Electric Hardware and Accessory Expert? Answer questions, earn points and help others
