Question about Greenlee Measuring Tools & Sensors
My greenlee cm-600 clamp-on meter just stopped reading ac and dc voltage correctly. On a 120 volt circuit it only reads 19-20 volts and will not read dc voltage at all.
SOURCE: VLT Error
chenge battery
Posted on Sep 29, 2007
  • 10865 Answers
SOURCE: voltage output is only 50 volts instead of 120 volts
If you need troubleshooting help for your Honda or other portable generator there's nothing better than a handy schematic. This detailed diagram will help you troubleshoot your portable generator. In publications or online you may find a variety of schematics for Honda or other portable generators.
One handy book, which can be ordered online and delivered straight to your home offers troubleshooting guidance, including a number of schematics, for Honda, ATI, Coleman, Generic, John Deere, Mitsubishi, North Star, Porter Cable and Robin Subaru portable generators.
The book, entitled, Small AC Generator Repair and Service Manual - 1st Edition Volume 2, is discounted for under $30 on one Web site.
This portable generator troubleshooting publication is 420 pages, replete with schematics in the former of illustrations and diagrams.
Posted on Jan 25, 2009
  • 10 Answers
More than likely your voltage regulator is out. The generator produces electricity, so you know the rotor and stator are OK. The 50 volts comes from the magnets permanent properties. The reason you are not getting 120 is because rotor or electron magnet is not getting any power supplied to it, which it needs to produce the amount of electrons you need to have 120vac. Make sure your engine is running at 60 hz first, and you should ohm out the windings and circuits that connect to your regulator.
Posted on Feb 05, 2009
SOURCE: MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Posted on Feb 19, 2009
  • 832 Answers
SOURCE: fieldpiece sc76
How many computers do you have? What kind of monitors you are using? The old CRT type, LCD type, or Plasma. All CPU, Monitors, and Printers have Watts ratings. From their ratings you estimate their electrical usage, by multiplying their respective ratings to the number of hours in use. You will have the pro-
duct in W-hrs. Divide it by 1000 to get the kwhrs. Multiply it by rate collected by your
local electric utility in cents or dollars per kwhr
to get the estimated cost of your computer
system. To get exact cost, you must hire
an electrical engineer to have energy audit.
Posted on Sep 22, 2009
Why would a new battery drain when car is turned off. I need to drive each day. If car sits battery will drain. I see others have had this problems. Has anyone founds an answer?
To test the car for electrical drains requires a digital volt ohm meter (DVOM) Best is to drive the car awhile so battery is close to full charge. Set parking brake and raise hood place the meter on battery red lead to + and black to - set dial to read DC voltage 20 volt scale This should read about 13.0 volts now start car and check again reading should be 13.2 volts or higher but not greater than 15.0 volt leave leads on battery and turn dial on voltmeter to the 1 volt AC scale this reading should be less than 120MV or .120 volts if good the charging system is in working order any thing out range you have a bad alternator. Now with car running make sure your accessories are off shut off car and exit note to watch for sentinel dome lights let then fade out. Now place DVOM on a ampere scale 10 amp preferred here is the tricky part place one lead in the center of the battery post and the other on the cable end slowly remove with out breaking connection this will read the total amperage draw against battery This draw after 10 minutes should be less than .300MA Milli-amps if it is not use a small hose clamp to keep lead on post and clip other to cable end touch battery until sentinel goes out and retest now start removing main fuses in fuse panel until draw is gone. Now you have identified the circuit that is causing your problem.
Aug 03, 2014 | 2004 Nissan Quest
Tip
How to use a voltage or multi meter.
You can buy a reliable, two probe voltage meter at most building supply stores for around $30. They typically have two testing probes and a dial to select the function. The four major functions are AC voltage, (a V with a wiggly line), DC voltage (a V with a straight line), resistance or continuity (the symbol omega), and amps(A). To use the meter you decide what value you are testing for and estimate what range the result would be in. For example, testing a receptacle, you would use AC Volts on a 200 range, expecting a 120 volt reading. For continuity or resistance, select a mid range to start with. Hold one probe to each side of the circuit or item to be tested. If the reading is infinite then there is no internal connection between the parts tested. If the reading is zero then there is a connection or a short between the parts being tested. For example, if you put the probes on the terminal screws of a switch, one position would give you a zero reading, and flip the switch and you would get an infinite reading. For a light bulb an infinite reading means it is burned out, a zero or close to it reading means the lamp is good.
You would use the DC Voltage function to check circuits in your car, or to check batteries. The car is 12volts DC and a battery is 1.5 volts DC.
on May 10, 2010 | Hammering
Stator replacement
Hi Anonymous, you will need a multimeter, first set it ohms on its lowest setting and touch the two meter leads together to calibrate the setting, then unplug the wiring harnes that goes to the stator. Touch one lead of the meter to one of the stator pins and the other lead to ground on the bike, meter should read infinity. Repeat the process with the other stator pin, reading should be infinity. Attach both leads to the stator pins and you should get a reading of 0.1 to 0.3 ohms. Next set the multimeter to the 100 volts AC range and hook the leads up to the stator connector pins. Fire up the bike and read the meter for every 1,000 RPM it should read 16 to 20 volts AC. If every thing checks out stator is fine. Set the meter to the 20 or more DC volts range and hook it up to the battery, voltage at 3,600 RPM should be 14.3 to 14.7 volts DC if not your voltage regulator is bad. And finally when ever you do any type of electrical diagnostics make sure you have a fully charged battery and all wiring and connections in the circuit you are testing are clean and tight. Good luck
Apr 23, 2014 | 2000 Harley Davidson FLSTC Heritage...
Line voltage indicator false indication of voltage variations
Voltmeters usually read RMS on ac volts therefore 120 volts is OK while the indicator is reading peak volts. If unit is operational there is no problem.
Mar 31, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
AC surge current?
you are missing the voltage supply here to get an definitive answer
for 240 volts drawing 4.8 amps the required wattage is 1152
for 120 volts the wattage is 576 watts
for 120 volts with a current of 900 watts , it equates to 7.5 amps
with 240 volts with a current of 1150 watts , it equates to 4.79 amps
so you can see the problem by not stating the supply voltage
get access to an cable clamp amp meter / watt meter from an electrician and read the current on starting the ac unit
if it exceeds 900 watts for 120 volts or 1150 for 240 volts , consider a bigger generator
Aug 31, 2017 | Fixya.com Heating & Cooling
How to use greenlee testervolt dvc-6
http://www.westwaysupply.com/fw487627.html
Here is the Instruction Manual in PDF file form,
http://www.mygreenlee.com/GreenleeDotCom/im/im1397.pdf
Shows which is the Fixed probe and which is the movable probe, which indicator LED's are for AC or DC, and Positive and Negative, and so on.
Voltage measurement (DC from 12 volt to 600. AC from 120 volts)
Continuity check (OHM's)
Resistance measurement (OHM's)
Identifying energized conductor
Ground Fault Circuit Interrupter test. (GFCI)
12 pages in English
Regards,
joecoolvette
Sep 17, 2012 | Televison & Video
How to use
Voltage testers and volt meters are two different things. A meter will provide a an indication of the exact voltage and type AC or DC. A tester on the other hand simply provides an indication of presence of power with little to no indication of how much or type.
AC power is what is provided by most power companies in the world. DC is a type of power provided by batteries and DC power supplies. If your tester or meter has provisions to check for AC and DC, you should check for BOTH. If AC power is present and you are have set your meter to test for DC power, your meter will indicate 0 volts. You can see this can be a dangerous condition. Most simple testers will not care if AC or DC power is being tested and the types that use neon lamps will usually glow differently for AC and DC power.
When setting up for testing voltage, you must test across the power source (or in "parallel") or load (such as a light bulb), as opposed to "in series" with the power source. Across would be from the + to - post of a battery, into the slots of an outlet, etc. "In series" is when the tester would be completing a circuit - such as testing across an open switch.
First, check the meter's operation by testing a known good power source by following the next steps. Set the meter for the type power to be tested. Choose AC if unsure. Next, set the meter for the highest voltage range supported. Make sure this range is higher than the expected voltage, otherwise damage to the meter may result. Connect the probes to the power source. Read the meter. If the meter moved only slightly, adjust the range of the meter to the next lower value. You can keep adjusting downward as needed to get the most precise reading possible - but do not set the range to a value less than the voltage present. A 0-300 volt scale is the lowest to measure a 240 volt outlet - switching to a 0 - 150 volt scale will damage the meter. The 0 - 150 volt scale would be fine for measuring 120 volt outlets.
If the meter did not move, change the type from AC to DC. and repeat. If it still does not work, the meter is not working correctly (if testing a know good source) or there is no power present (if the meter worked on a known good power source).
May 12, 2012 | Measuring Tools & Sensors
I have a ge2524 digital mulitmeter. When i check a 9volt batter it reads 16.3 when I check a 12 volt battery i get 21.7 when I check a 120v circuit I get 183. this meter is not that old and the...
change the meters battery,when they get low they will read higher than normal voltage as in line plug should read about 120 volts A.C.,when the battery gets weak it may read 140 volts A.C.
Aug 22, 2011 | GE Measuring Tools & Sensors
I just purchased yesterday and found recall notice in upper tour pack. The battery was low charged over night and am going to check voltage and amps at battery while running today. What are the telltail...
With the battery fully charged, use a DVOM (digital volt ohm meter) to check the output of the charging system. Connect it across the battery, red meter lead to positive, black meter lead to negative. Put the meter's function switch in DC VOLTS, 20 VOLT range. Start the engine and bring it to a high idle of about 1500-2000 RPM. The meter should read 14.5 to 15.0 volts.
If the meter does not read correctly, unplug the regulator where it enters the front of the engine case. You'll be measuring the AC voltage at the engine case side of the plug. Put your meter's function switch in AC VOLTS, 50 VOLT range. Put one meter lead into one metal contact in the plug and the other lead into the other metal contact in the plug. Makes no difference which lead goes to which metal contact. Start the engine and bring it to a high idle. You should read 30 volts or better.
If you do not read 30 volts at the engine, your stator is bad. If you have 30 volts or more at the engine but low voltage at the battery, your regulator is probably bad. This is a simple test and it's accuracy is about 90% or so.
Good Luck
Steve
Oct 31, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I got a output voltage of 100.1 on a trace dr3624
The rms voltage is what counts, because it tells how much power the output will deliver to a resistive load. Inexpensive multimeters on their AC ranges are usually average-responding rms-calibrated meters. This means they measure the average of the absolute value of the AC component of the signal, and display that average multiplied by about 1.11 (actually, pi over sqrt(8)), the ratio of rms to average value for a pure sine wave. That way, the meter will give the right rms reading for a sine wave.
If the signal is a square wave, where the average and rms values are equal, the average-responding meter will read 11% too high.
Many inverters put out a modified sine wave (MSW), which sits at zero for a while, goes to a constant positive level for a while, goes back to zero for a while, and goes to a constant negative level for a while to complete the cycle. The positive and negative parts of the signal have the same magnitude and duration.
The rms and average values of an MSW depend on its duty cycle D, the fraction of a cycle for which the signal is not at zero. In a well-designed inverter, the duty cycle will be adjusted when the DC input voltage goes up and down to maintain the nominal rms output voltage. If we use peak voltage Vp to mean the magnitude of the positive and negative voltages the signal goes to, then Vavg for an MSW is equal to Vp times D, and Vrms is equal to Vp times the square root of D.
The duty cycle for which an MSW will have the same rms to average ratio as a sine wave is 8 over pi squared, or 81%. For any duty cycle less than this, an average-responding meter will read a lower voltage than the inverter rms output, and for a duty cycle higher than this, the meter will read too high.
If your MSW inverter is putting out 120 volts rms and its duty cycle varies from 50% to 75%, the meter reading will vary from 94 volts to 115 volts. I avoid the problem by using a Radio Shack 22-174B true rms digital multimeter.
Aug 27, 2009 | Xantrex Technology DR2412 Inverter /...
Measuring Tools & Sensors Logo
124 people viewed this question
Top Greenlee Measuring Tools & Sensors Experts
Wbix
Vuk B
Tom Chichester
Are you a Greenlee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
