Question about Norelco 8140XL Electric Shaver
Why do the plastic drive gears underneath the shaving head keep breaking off? Thisis the third Norelco 8140Xl this happened to.
  • Norelco Master
  • 1,600 Answers
If this is a repetitive problem for you, there must be a reason. Most likely, the blades are getting jammed and this is causing the tips of the gears to twist off. To prevent this from happening, make sure that you disassemble the shaver heads and thoroughly clean the teeth on a regular basis to prevent them from getting clogged solid. Also, make sure that you are protecting the delicate combs of the shaver head to prevent them from getting damaged. If the comb gets damaged, the teeth on the blade will lodge in it and this can cause the gear tip to break off.
You can replace thesebroken gears. You will find the required part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
Posted on Oct 04, 2010
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
Philips norelco sensotouch replace the shaving unit. replace damaged razor heads
You will find RQ11 shaving heads at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-rq11-sensotouch-replacement-heads.html
Mar 01, 2015 | Norelco Health & Beauty
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
Norelco 8140XL motor gear assembly
You will find partial instruction to disassemble the shaver at the link below. You will also need to remove the gear plate by removing the two screws in the hair chamber. Then just disconnect the wires from the motor by pushing in on the small metal release next to the wires on the motor while pulling on the wires
https://www.youtube.com/watch?v=rGD84BfKxAE&feature=c4-overview&list=UUc_zJiCUI8mpLyYlwCxo8IA
Jun 08, 2013 | Norelco 8140XL Electric Shaver
Will my norelco 8140 xl electric shaver work with the electrical system in Israel (220v) without a converter? Will I need an adapter?
Yes. the charging cord for model 8140XL have a built in voltage converter and can be used with 100-240V
Dec 23, 2010 | Norelco 8140XL Electric Shaver
Where can I get the stems on the motor / gear assembly ( 4222 036 1290) for norelco 8140xl shaver
You will find this item at shaveroutlet.com. See link below<br /> <br /> <a href="http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html">http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html</a>
Aug 29, 2010 | Norelco 8140XL Electric Shaver
Red light came on in the form of the heads. Is it time to replace
This means that it is time to change the shaving heads. You will find Arcitec replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 11, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Norelco Replacement Razor Heads for ...
Norelco 8140XL Electric Shaver Logo
142 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
