Question about HP DeskJet 5150 InkJet Printer
Won't install put install disk in, the wizard starts, then gets to a point where it says "rolling back action". i get a window that says i need a file called hpzm309.dll i can't find such a file. the reason i am reinstalling is a hard drive crash which has now been fixed. had no problem installing my scanner, but can't get the printer going. help!!! mike
    Scholar:
  • 139 Answers
Since u cant find the file i suggest u use deskjet plus to do the installion. all will work well but u might not be able to print in color.
u use this if u need an urgent print out in black i only suggested
cos each time i fix some ones printer i use deskjet plus for deskjet n laserjet plus for laser jet n it works all fine without installaion disk.
thank u
Posted on May 27, 2008
Hoe to start withouten compaqdisk
You can install windows 7 then should identify components using
SiSoftware Sandra SiSoftware Sandra
Loclise those drivers not provided by Windows, using google and the component.
In control Panls hardware Administrator you can check tohse components with missing driver.
You should check first at HP's website
May 12, 2015 | HP Compaq Evo N1000v Notebook
Windows keeps finding new hardware nd trying to install it. I put in the disk, but xp won't use the files
Run the driver from the disk by clicking on the execution file ..or running the auto-installation ..and only attach the printer when it asks or after the driver is installed ..
Or ...plug the printer...and let the wizard start ..select not to look for the driver on the net ..but to select it from a location ...click the case that will alow to browse for a location ..and point the search to the disk drive ..and click next ..this way you will force windows to install the driver for it ..
If on the disk are several drivers for more than one operation system ..you will have to select when browsing the driver folder and specify the xp one ..
Sep 07, 2011 | Lexmark X75 All-In-One InkJet Printer
Daughter deleted some of the programs on the computer, how would i just set the computer back to start/just purchased settings so that i can lock everything so that she does not do this again? Thanks in...
when you bought your computer you must have got a back up cd with it to reinstall everything as it was.. I mean factory installed/default.. If you did not got this cd try this:
Using Windows 7 or Vista System Restore
Windows 7 and Vista has a feature called System Restore that automatically backs up registry and system files whenever you install new software or drivers. This feature is useful when you install evil software that makes your computer run really slow. But don't worry, System Restore won't remove Windows Vista/7.
Using System Restore in Windows
There are two places that you can use the system restore feature from. From within Windows, you can just type restore into the Start menu search box, and you'll immediately see System Restore at the top of the start menu:
Or you can type rstrui into the search box and hit enter. Your choice.
You will immediate see a screen where you can choose to roll back the system to the last restore point. You can select "Recommended restore", and just click next, or you can choose a different restore point.
If you do choose a different restore point, you will see a list of restore points that you can choose from. How many times have I typed the word choose at this point?
Click one of them, and you will have to confirm and then restart your computer to roll the system back.
If you receive an error while restoring, then use it from safe mode and it should work fine. To get into Safe mode, you can reboot and use the F8/F2 key right before Windows starts up.
If Your System Won't Boot
If you can't even get into windows, you can boot off the installation dvd, and choose the "Repair your computer" option on the lower left hand side. If you don't have an installation/repair disc, you can make one with these instructions.
Click next on the next screen, and then choose System Restore from the System Recovery dialog. It will take a few seconds to come up, and you will see the same screen that you would see in Windows:
Click next, and on the next screen select the drive that your copy of Windows 7 or Vista is installed on.
Click Finish, and Windows will roll back to the previous restore point. Really pretty simple stuff.
hope this helps you out, if it helped you out please like/rate the answer please, it will really help
Jun 03, 2011 | Disney Netpal by ASUS Princess Netbook
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I want to restore my last week set up? how to do?
Using Windows Vista System Restore Windows Vista has a feature called System Restore that automatically backs up registry and system files whenever you install new software or drivers. This feature is useful when you install evil software that makes your computer run really slow. But don’t worry, System Restore won’t remove Windows Vista.
There are two places that you can use the system restore feature from. From within Windows, you can just type restore into the Start menu search box, and you’ll immediately see System Restore at the top of the start menu:
95afb90.png Or you can type rstrui into the search box and hit enter. Your choice.
You will immediate see a screen where you can choose to roll back the system to the last restore point. You can select “Recommended restore”, and just click next, or you can choose a different restore point
23c0f17.png If you do choose a different restore point, you will see a list of restore points that you can choose from. How many times have I typed the word choose at this point?
You’ll notice in the screenshot below that the last thing I did was install Virtual CloneDrive to mount ISO images, but right before that I installed the NVIDIA drivers.
323d69a.png Click one of them, and you will have to confirm and then restart your computer to roll the system back.
6022678.png If you receive an error while restoring, then use it from safe mode and it should work fine. To get into Safe mode, you can reboot and use the F8 key right before Windows starts up.
If Your System Won’t Boot
If you can’t even get into windows, you can boot off the installation dvd, and choose the “Repair your computer” option on the lower left hand side. .
da0479a.png Click next, and on the next screen select the drive that your copy of Windows Vista is installed on.
Click Finish, and Vista will roll back to the previous restore point.
Aug 11, 2009 | Dell Inspiron 6400 Notebook
I lost my installation disk and got a new computernow i cant install it
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
If you have Vista check if your model is on this list: Windows Vista -- Lexmark United States.
Jul 31, 2009 | Lexmark Inkjet Z517 Photo Printer
Need installation software for lexmark z600 series printer in vista home basic
Put Z601 (all z60X have same driver) in the model, chose Vista operative system and download the file called cjrZ500-Z600EN.exe
After downloading, find the file, open the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
Note : to open the file do not use double click, but click the right button of mouse on the installer file and chose "Run as Administrator"
Apr 08, 2009 | Microsoft Windows Vista Ultimate Edition
Can't get Vista to restart
Start windows, befor Ram loads hit F8 / F9 / F11 so u can acces to Boot Menu
then Hit Safe Mode it will loads windows but with restricted opcions then go to Start menu --> execut or Go
and then type CHKDSK and reboot
if it doesnt work ull have to restore your system
ull have to boot on safe mode and do this it will work 100/100
1.
Click Start, click Control Panel, click Performance and Maintenance, and then click System.
2.
In the System Properties dialog box, on the System Restore tab, use the slider to increase the allocated disk space, and then click OK.
If you're using more than one drive on your system, follow these steps:
1.
2.
Click the drive you want to monitor, and then click Settings.
3.
In the Settings dialog box, shown in Figure 1, use the slider to increase the disk space, and then click OK twice.
Figure 1
Notice that the disk space allocated to System Restore cannot exceed 12%. If you need more space, you can run the Disk Cleanup utility to reclaim space. To open Disk Cleanup:
• Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup.
arrow_px_up.gifTop of page Before You Try System RestoreSystemRestore should only be used after trying less comprehensive methods oftroubleshooting. System Restore changes many files and registryentries, and in some cases might replace more files than you wantrestored. So when I first run into a computer problem, I reboot mycomputer. I'm still amazed at how often a problem is solved by usingthis simple technique. Or, if your computer won't start in normal mode,reboot your computer, press F8 during the boot process, use the arrowkeys to highlight Last Known Good Configuration, and then press ENTER.
Other troubleshooting techniques that often work are listed below.
Run problem applications in Compatibility Mode if system instability occurs after installing a particular application. To run the Program Compatibility Wizard:
• Click Start, point to All Programs, point to Accessories, and then click Program Compatibility Wizard.
Use Add or Remove Programsto uninstall a problem application if the system instability hasoccurred immediately after a new application has been installed andrunning the program in Compatibility Mode hasn't helped. AlthoughSystem Restore will remove the application if you choose to apply it,it is better to remove the offending application from Control Panel. Toopen Add or Remove Programs:
1.
Click Start, click Control Panel, and then click Add or Remove Programs.
2.
Click the program you want to remove, and then click Change/Remove.
If the system's instability has occurred immediately after a new device driver is installed, use the Device Driver Rollback feature instead of System Restore. To roll back to an earlier driver:
1.
Right-click My Computer, and then click Properties.
2.
On the Hardware tab, click Device Manager.
3.
In the Device Manager dialog box, double-click the hardware that uses the driver in question.
4.
In the device Properties dialog box, on the Driver tab, click Roll Back Driver.
See Charlie Russel's columns, Device Driver Rollback Beats BSOD and Finding Compatible Device Drivers for Windows XP, and Paul McFedries' column, Troubleshoot Device Driver Problems, for more information about device drivers.
Work through the Windows XP troubleshooters in the Help and Support Center. To open a troubleshooter:
1.
Click Start, and then click Help and Support.
2.
Under Pick a Help topic, click Fixing a Problem.
3.
Under Troubleshooting problems in the right pane, click List of troubleshooters, and then start a troubleshooter by clicking the name in the left column of the table.
If,after trying these options the computer is still unstable, opt forSystem Restore. You'll want to save this option for last because thechanges made to your computer are more comprehensive than if you simplyuninstall a program or rollback a device driver.
Use System RestoreAfteryou've decided to use System Restore to revert your system to aprevious state, start the System Restore Wizard and follow the prompts.To use the System Restore Wizard, make sure you're logged on as anadministrator, and then follow these steps:
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
Nov 13, 2008 | Computers & Internet
Could you help me put my lexmark 1200 onto my computer i have windows vista
You need to run installer software from printer disk, before connecting the printer usb to computer.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Nov 07, 2008 | Computers & Internet
I haven`t got a installation disk for my printer, so it won`t connect to my computer .
Note:some printer does not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Sep 04, 2008 | Lexmark P706 Photo Jetprinter InkJet
HP DeskJet 5150 InkJet Printer Logo
257 people viewed this question
Seeker5211
Seeker5211
