Question about Sony VAIO VGN-CR220E/P Notebook
My Sony Viao wont stay charged and when i try to power it up, it shuts down by itself at the sign in screen. It wont let me get past the sign in screen,
    Novelist:
  • 112 Answers
Are you using a Sony Battery or an aftermarket cheaper version?
If your battery has been changed to a different brand then thats your problem and a whole problem in itself.Not saying there is anything wrong with that, but the Sony ISBmngr.exe file will stop the charging of any battery exept Sony's and put the system into hibernation mode. ( website with Info below)....
If you have the original manufacturers battery then go on.
This is the typical charging-plug, jack, for laptops. Many times the plug itself is bumped over time and pushes on the pin in the center. The charging time becomes very short, if at all, because the connection is broken.Some are completely or because of the position of the wire holding it just right long enough to give a short charge.
My Sony Viao wont stay charged and when i try to - 32917b9.png With a Voltmeter ,check the output of the charger itself to be sure it is working properly.
Although VIAO has been out for a while & because the model was not listed here the age of the battery may also be in question. If the battery has shorted out and the charging unit & jack are fine then a bad battery that has shorted will cause you symptoms also. Try removing the battery and running on the charger alone.
Here are a couple of sites that I found that deal with Sony VIAO's
1. http://www.ghacks.net/2008/02/02/sorry-you-cannot-use-that-battery-because-it-is-not-made-by-us/
2. http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
3. http://sarabannerman.blogspot.com/2007/04/sony-laptop-battery-mal-ware.html
Posted on Oct 07, 2010
Sony viao windows xp os over heats and shuts down
Grab a can of compressed air and clean all vents on a back and on a side.
Clean the area around the processor fan
Get a cooling pad
Aug 25, 2014 | Sony VIAO Laptops (Laptop NOT Included)...
Sony Viao VGC JS1160J keeps shutting down, then powers back on
it shuts down and powers up itself or u can power it up in a few secs again ?
if second statement then it may be coolers fault. notebook can shut down if too much heat
try using everest ultimate edition to check temperature in your pc
if higher than 70 buy additional cooler in store
Oct 07, 2012 | Sony VAIO VGC-JS160J/S Notebook
My laptop powers up but the screen stays black then it shuts itself down
It could be the CPU fan... Best to have it looked at by a service center...
Aug 12, 2012 | Toshiba Computers & Internet
Sony Viao laptop just started shutting itself down while I was working on a word document. Laptop will not stay on more than a minute or two after booting up even if nothing is open. Battery is charged
Disconnect external devices. Remove battery and power cord. Then reposition them again. Be sure battery is locked with the switch at the bottom of the unit. Keep charger connected. If issue continues it may require service.
If you can see VGN-CS on the upper left corner of the lid (your unit's model number) you will need to call Sony as this is a known issue
Mar 26, 2011 | Sony Computers & Internet
My sony viao laptop has gone into sleep mode or just wont start up. I have started it and have seen the viao splash screen and then it looked like it was gonna load but went to a black screen now I cant...
try to restart your laptop in SAFE MODE WITH NETWORKING. once you are in safe mode with networking change power settings from power option in control panel. Try SYSTEM RESTORE. Still you face problem press F8 when you turn your laptop on. You will get advance options. Select LAST KNOWN GOOD CONFIGURATION.
May 04, 2010 | Sony VAIO VGN-S460 Notebook
Screen is dead
  1. turn off the computer
  2. take off the ac adapter and remove the battery
  3. reseat RAM/memory
  4. without the ac adapter and battery, press and hold down the power botton for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
hope this helps
Mar 02, 2010 | Sony Computers & Internet
Screen shuts off
this happens when the processor gets over heated.--- normally the speed of the fan that cools the processor decreases due to dust in it.just clean the processor fan and apply a air blower with full pressure on it to remove all the dust.this will help.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Pcg-fxa49 won't boot
Could be it needs the DC jack resoldered or replaced. (Sounds like its trying to start off dead battery).. These arent to bad to do compared to others weve repaired. Good luck!
Jan 29, 2008 | Sony Vaio PCG-FXA Series AMD (A8058677A)...
Sony VAIO VGN-CR220E/P Notebook Logo
205 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
