Question about Fisher and Paykel IWL12 Top Load Washer
Fault 37. Machine will not empty bowl - Fisher and Paykel IWL12 Top Load Washer
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now error code 37 is called PUMP BLOCK ERROR Do you hear the pump pumping any water if you advance the cycle to spin and push the start button?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Oct 04, 2010
Fault 37
37. (00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3
minutes. There are three likely reasons for this fault. One is that the drain hose or the
pressure switch hose has been squashed or kinked and the pump out rate has been
dramatically reduced. The second possibility is that the pump is partially or fully blocked.
The third is that the pump is not operating due to Motor Control Module, wiring or pump
failure. This fault could also appear if the machine is pumping to an unusually high head of
drain hose or into an extended length of drain hose. The fourth possibility is a diverter
valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation
mode, giving the module the appearance the pump is not lowering the water level.
Primary Source: Pump System.
Action: 1) Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 1-metre extension hose of the same diameter
fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the bowl is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain
hose is not blocked.
5) If the bowl contains water, then service the pump from the top of
the machine by removing the top deck and inner bowl. Bail out the
water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action: 1) Check the pump harness is connected correctly to the pump.
2) Check continuity of the pump harness.
Tertiary Source: Motor Control Module.
Action: Activate the pump by operating the machine in spin mode. Check the
pump is rotating. If it is not operating, and Primary and Secondary
checks have been performed, then replace the Motor Control Module.
Dec 29, 2013 | Fisher and Paykel Washing Machines
Fault no. 37
Nov 23, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My fisherpaykel top loader washing machine wont drain water or spin it beeps and 3 lights come on
I worked out that code to be 37
info for fault 37
Dec 05, 2012 | Fisher and Paykel Washing Machines
GWL11 washer stops draining on first rinse cycle
That fault code is 37.
Disconnect from power & Bail out all the water you can before removing pump.
Here is some info on fault 37
Jul 26, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL11 washer not going into rinse cycle, getting error code 37
Pump should read
110V AC pump 60Hz 7Ohms +/- 8% @ 20oC
230V AC pump 50Hz 33Ohms +/- 8% @ 20oC
Jul 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
What is fault 40
Fault code 40 info
40. (00101000) Bowl Dis-engage Fault
While carrying out a bowl check, the Motor Control Module has found that the bowl is not
engaged even though the pressure sensor indicates that the bowl is empty. The Motor
Control Module continues to check for 2 minutes, after which time it displays this fault. The
first two areas to check are the clutch and the pressure tube. If these two appear correct,
then the fault could be in the pressure sensor in the Motor Control Module.
Primary Source: Mechanical.
Action: 1) Check that there are no clothes or other foreign objects preventing
the clutch from re-engaging. Excessive suds can stop the bowl
rotating.
2) If the machine is empty of water, carry out a clutch disassembly
procedure and check the spline drive.
3) Next check that the pressure tube has not come off and that it is
not kinked.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
May 07, 2012 | Fisher and Paykel Aquasmart wl80t65c
Fault 40 comes up
rotating.
not kinked.
How do we dis a fault 37 on my fisher and paykel washing innovative washing machine?
May 02, 2012 | Fisher and Paykel Washing Machines
Fault code 37
fault code 37. washing machine will not empty bowl.
Feb 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Intuitive washer
Lets clear this one up. There is not filter on a Smart Drive, Yon will need to removed the top deck of the machine, then the agitator, then the inner bowl. You will then be able to access the pump cover (front right hand side of outer bowl). Removed the screw retaining the cover, then remove the obstruction, it will probably be hair clips, bra underwires etc
Mar 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel IWL12 Top Load Washer Logo
390 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
