Question about Palm Treo 650 Handheld
Won't charge My phone's charger will not hold the charge, when I put it in it will be red and then jump to green. When I go to cut the phone on it says that the battery is too low and cuts off. I was trying to charge it from a usb but I don't see the pos and neg side of my battery. Please help
  • 28 Answers
If battery fits, you've put it in correctly. Time for a new battery. They're cheap. www.ebay.com
Posted on Jun 14, 2008
I have a 18v battery charger for my great neck drill but the red light insant lighting up when I go to charge my my battery, but the green one is lit up.
Try jump starting the battery. Li Ion batteries often have smart chargers if the battery gets to low the charger doesnt recognise it. If yo have a spare battery fully charge it ant then conect + to + and - to - with wire ( may take two people) kep them connected for 2 mins or so then try in the charger.
Worked for me
Dec 17, 2010 | Great Neck 80125/79681 Cordless 18V Drill
15 min energizer charger cuts off after 5 seconds
Plug it into mains without battery.
Put the battery(s) into place. If batteries OK (but need charging) it will begin charging. If batteries very low it will cut off. If batteries charged it will charge only 1 - 10s.
Jun 07, 2010 | Energizer 15 Minute Battery Charger Combo...
I am not able to charge my cell phone HTC P3452
Hi
If you are not able to charge your cellphone, there are several factors why:
  1. your charger connector is defective
  2. your charger terminal is defective
  3. your battery is defective
To solve this, you can check your charger connector with multitester, if it's working or not. If you test it and there's a movement, then the charger is OK. Next, check the charger terminal, using multitester. If there's a movement, then it's OK. and you'll know that the problem is on the battery.
May 25, 2010 | HTC Touch P3452 Smartphone
Ntn7143cr battery won,t charge. put in charger flashes red then green.
Clean your battery contacts on the battery and charger with a pencil eraser to assure good contact. Flashing red or flashing in general usually is the sign of a too low to charge battery, a shorted battery or a bad connection. In some instances, a battery will begin to charge once left on the flashing charger for an hour or so. Try this and see if the light becomes constant. If so, it is charging. If it still flashes, replace the battery.
Best regards.
Apr 04, 2010 | Motorola MT1000 Compatible 2 Way Radio...
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
8125 will not reboot
You need to jump start the battery.. The phone's charging capability is controlled by software (pretty dumb) so without enough juice from the battery it won't charge.
Grab an old USB cable (or other 5 volt source) and cut off one end.. take the red wire and put it on the battery contact on the end with the red plus sign. Put the black wire on the other end. Hold the wires there for about 3 minutes. Be careful not to switch the positive and negative.
Now reinsert the battery into the device, and without turning it on, plug in your charger. the charging light should come on shortly, and just leave it off charging for about an hour before turning it on..
Thats all Folks
Dec 04, 2007 | Cingular Wireless 8125 Smartphone
Audiovox SMT 5600 will not charge
If your battery goes COMPLETELY dead, which it will do if phone is not turned OFF and not used for a long period of time, you will need to JUMP START it using you OEM SMT-5600 AC charger. Other AC chargers will not work for this purpose and neither will a USB port.
You can JUMP START the battery using a USB port by cutting off a USB cable to expost the red and black power USB PORT power pins 1 and 4. Remove your SMT-5600 battery and while the modified USB cable is plugged into your USB PORT, hold the BLACK wire to the negative (-) terminal and the RED wire to the positive (+) terminal for about a minute. Replace the battery in the phone and connect the phone to a USB PORT using a standard USB cable. The SMT-5600 charging light may not register for a while, but will eventually light amber to show it is charging, assuming your phone is recoginzed by your computer.
Note some mini USB cables DONOT carry the USB power leads through to the phone, only data. If you have a very thin USB cable, be suspicious the power leads are not being carried in the cable.
Since the USB PORT power is limited to 100ma it cannot hurt the battery, but will insert enough current into a totally flat batter to cause the battery to register a voltage large enough to alllow USB PORT charging, typically 3.7VDC.
Nov 18, 2006 | Audiovox SMT5600
Palm Treo 650 Handheld Logo
32 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
