Question about Gardner Bender GB Electrical GDT-190A 19-Range Digital Multitester
DO I NEED TO TAKE OUT FUSES OUT OF PANEL OF CAR TO CHECK THEM IF THIER BAD OR NOT
  • 760 Answers
Two ways to check. You can take them out and test them with the ohm meter . Or leave them in circuit and test 12V to ground on each side of fuse. Notice the two small metal tabs on each fuse. Touch your tester to these. You should get a reading on both sides. If only on one (incoming) and not the outgoing then fuse is blown. Note it will only work if the fuse is on (key on acc if it is a switched fuse)
Posted on Oct 04, 2010
2002 honda crv starts but dont go into gear
Check all fuses look in owners manual for fuse compartment locations Any wires that were cut behind radio need to be repaired If installing an aftermarket radio you should purchase a radio connector adapter @ wal-mart or just about any auto parts store
Apr 18, 2013 | 2002 Honda CR-V
THE RADIO JUST WOULD NOT COME ON. tHE LED INDICATOR WOULD NOT ALSO BLINK AS USUAL.
I would check your fuses to see if one is blown, Start by checking in your fuse panel first and work your way to behind the radio where you should find some inline fuses. If no blown fuses are found you will need to check for a loose wire behind the radio. If all of the above are good chances are the radio is bad and needs to be replaced.
Aug 09, 2011 | Car Audio & Video
Alternator is not charging but the local parts store tested it and it is working fine, all fuses are good
what makes you think its not charging? alternators should always be checked ON THE CAR.
Aug 03, 2011 | 1999 Oldsmobile Alero
Microwave range MV1526W dead. Want to check the fuse.
the fuse is behind control panel to access it remove top grill and you see screw that holds the control panel. the fuse will be white with a metal tip at each end,FUSES DONT BAD FOR NO REASON if the fuse is blown then you also need to rerplace the door switches (their is at least 3 of them if not more) I HIGHLY RECOMMEND THAT SINCE THIER IS VERY HIGH POTENTIAL FOR DEATH FROM ELECRICUTION AND RADATION HAZARD THAT YOU CALL A PRO TO REPAIR THIS
UNPLUG BEFORE ATTEMPTING ANY DIAGNOSIS
Jul 20, 2011 | LG LMV1645 Microwave Oven
Airbag light is on in 97 Town car. Have identified the code as 12, by the flashing pattern. Where can I find the code to solve the problem?
shaid tree,1,2,3. T had the same problem with my 1997 cartire, Frtst off you must find the fuse box which is located under drtvers side dash. remove the fuse block cover,there you will find sevral tipes of fuses rainging from 5,10,15 & 20 amps. check the fuse corresponding with the altinator, thier are two (2) of them .1 (one) there and the otherin the power fuse box under the hood on the passenger side if the car.if found to be bad Replace the fuse with the same type {examp a 5 out a 5 in ) fuse that was removed from thier spots. 3 make surt there is nothing lying on the hood or motor that will fall into turning parts and cause ingery. Staet Engin.Check airbag light if on recheck fuses,if the fuses are blown.you may have a short to ground if fuses are not blown and the tight is still on you may have a bad alternator.some say that I had clock spring problem but Im the end it was just a fuse
Mar 28, 2011 | 1997 Lincoln Town Car
My electric windows will not come down my ford ka r reg i want to check the fuses but do not have manual and i do not know which one is for the windows
try takin out the fuses out one @ a time check to see if they have blown you will kno what one has blown the wire in the fuse will be broke on some cars when you take the cover of that hides you fuses thier is pictures on the back of the cover telling you what number and what rating the fuse is hope this helps
Feb 05, 2011 | Ford Car Audio & Video
Front lights don't work and turn signals. checked fuses and thier good, what else could it be?
check for loose/broken wires and connections. also a bad/cut ground could be at fault so check grounds to the body too.
Jan 05, 2011 | 1997 Cadillac DeVille
Cannot locate ac fuse possible needs to be replaced air is only blowing hot. sealed and added cub zero
under driver side dash, i think it also depends on what kind of car you are driving. Thier is also a fuses panel by the battery (most of the time) under the hood. On my caddy thats where the ac fuse was located
May 06, 2010 | Max American Terminal 30 i Fuses
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
BMW 323 1999 AC problem
you might have them check the blower motor for the fan while they have the car.sounds like theres a short somewhere but it could be in the fan.maybe a regulator or something is bad in the ac system
Aug 09, 2008 | 1999 BMW 323 Series
Gardner Bender GB Electrical GDT-190A 19-Range Digital Multitester Logo
144 people viewed this question
Top Gardner Bender Measuring Tools & Sensors Experts
Vuk B
adesilva_199
Level 1 Expert
Are you a Gardner Bender Measuring Tool and Sensor Expert? Answer questions, earn points and help others
