Question about Eureka Vacuums
I have a eureka bravo upright model 9600. I have removed the hood . I need to remove the brushe roller to install a new belt. I cannot figure out how to remove the brush roller.
  • 377 Answers
Check out this URL:
http://www.svcvacuum.com/beltrep2.html
looks like it has just what you are looking for. Would appreciate a thumbs up on this if you find it beneficial. Paul
Posted on Oct 04, 2010
  • pwillitz Oct 04, 2010
    Thank you very much for the rating and for taking the time to do it.
    Greatly appreciated.
    Paul
How to replace eureka model 4388 belt
Hi, it's Allie from Crucial Vacuum!
Changing the belts in your unit is easier than you think. To do so, you will need a phillips head screwdriver. First, start by unplugging your vacuum as a safety measurement. Using the lever in the bottom of your unit, recline your upright until it lays flat. Unscrew all 4 screws from the floor base cover and remove the cover to expose the roller brush and belts of your unit.
Carefully, remove the roller brush by using your hands, make sure to hold on to the side of the roller brush that has the belt so it does not pop out and hit you. Once the roller brush is removed, gently take the belt off the metal spool, and replace with the new belt.
We have a very helpful tutorial in our webpage that can assist you in replacing the belts on your unit:
https://www.youtube.com/watch?v=IFcjzuplX_o
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-style-u-belt-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 19, 2014 | Eureka Whirlwind 4388 Bagless Upright...
Eureka TRUE HEPA Whirlwind Bagless same problem seems...roller just stopped...took everything apart and turned it on just in time to see belt melt...I was able to get the end caps off both sides at first...
If you are able to remove one end cap, the brush roller shaft can be removed and the other bearing is exposed for examination and removal of the hair that probably is clogging it. After cleaning and reassembly the brush roller should rotate freely. Clean any burned belt residue from the motor shaft and install a new Eureka belt.
Aug 02, 2013 | Eureka 2961AVZ Bagless Upright Vacuum
Belt
Look underneath where the brush roller is located. The brush roller is removed to replace the belt. The new belt is installed on the motor shaft and the brush roller then the brush roller is reinstalled
Jul 27, 2013 | Eureka Whirlwind 4481 Upright Vacuum
Trying to change the belt
things you will need Vacuum belt
  • Screwdriver
  1. Locate and purchase the correct belt for your Eureka vacuum cleaner from the local grocery or department store. Vacuum belts come in different sizes according to your model of vacuum. Check your owner's manual or the vacuum itself for your model number.
  2. Turn your vacuum cleaner over so that the bottom of the unit is facing you. Remove the cover plate from the bottom by undoing the screws that are holding it in place with a screwdriver.
  3. Locate the belt pulley rod near the back of the vacuum base coming out of the motor. With the vacuum cleaner base turned upside down and facing you, the motor and pulley rod should be up near the top of the base.
  4. Slide the vacuum brush roller out of the slots at the bottom of the vacuum base and remove the old belt from the brush roller and pulley rod. With the brush roller off of the unit, clean the brush by removing any strings or cords wrapped around the tube.
  5. Install the new belt by looping it over the belt pulley rod next to the motor and then looping around the end of the brush roller in the belt slot. Hold the brush roller and pull back on it to tighten the belt while you slide the roller back into the slots on the vacuum base.
  6. Replace the base cover plate by snapping it back into place and securing it with screws. Turn vacuum back upright and turn it on to test the belt and verify the unit is working
Feb 16, 2011 | Eureka Surfacemax 200 Bagless Upright...
Lost manual on vacum need to replace belt
Remove the bottom cover of the sweeper head, then remove the brush roller along with the belt if still there. Clean the brush end-bearings--the roller ends and the interior of the bushings. Then oil the bearings lightly with 3-1 oil or similar. Place the new belt over the roller and the motor shaft adding any required belt twist (diagram on the casting), then seat the roller and bearings as a unit. Replace the cover and test the roller for running. Hope this helps!
Oct 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How to change belt on eureka whirlwind; what tool do I need
You will first need to remove the hood to gain access to the belt and brush roller. Turn the machine upside down, place the handle on the floor and the base on a counter. You will find several screws that hold on the hood, remove them. Turn the machine back to the upright position and remove the hood. On the right hand side,if your looking the front you will find where the belt goes. At the back you will find a silver shaft sticking out, put the new belt on there first. Then put the brush roller through the belt so it is in the carved out section of the brush roller. Then grab the brush roller by each end and stretch the belt till the brush roller fits back into the base. Turn the brush roller 3 compleat turns backwards and 3 forward to seat the belt in the proper position.
Then put back on the hood.
May 08, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
Belt tensioner overheated and doesn't keep belt tight enough
Looking at the owner manual, there is no tensioner assembly.
If the motor is fixed in place and not loose, then you either have the wrong belt, or the brush roller is not properly installed, or the brush roller is worn out where the belt goes around the brush roller.
Dec 16, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
377 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
