Question about GE WJSR1070A Top Load Washer
Water overflows drain pipe when draining.
I have had a plumber out twice because my drainpipe overflows when the washer is draining. The first time the plumber snaked the pipe and the machine was fine for 6 weeks. He came back and said it has to be a suds buildup because there wasn't anything in the drain the first time he snaked it so he didn't do it the second time.
Can you help? How could I get rid of the suds buildup?
Thank you.
  • Anonymous Feb 08, 2009
    I have the same problem and want to know if there is a way to turn down the rate of pump emptying the washer
    Genius:
  • 1,028 Answers
You don't you get a different plumber may only be a partial restriction in drain line and could be any where down the line water is pump out on some washer faster than a restricted drain can handle it and no there is no way to reduce rate water is being pump out..been there have the t-shirt
Posted on May 29, 2008
My estate washer continually runs water in the basin but won't fill up. It drains immediately out as the water runs in. What could be the problem?
Assuming the motor isn't running during fill the water is siphoning out and can be caused by a few things.
· The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high.
· Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break.
· If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe.
Feb 08, 2011 | Whirlpool Washing Machines
My water is draining out of my machine as it is filling, Why?
This is a condition known as syphoning. Your drain hose on the washer needs to go up before it connectes to the house drain. It needs to rise as high as the washing machine top then hook over the drain pipe. If the drain hose is pushed too far into the drain pipe this can also cause syphoning.
Here are some tips to help describe this better.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe?
The drain hose may be too far down inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure that the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shape drain hose form (as described in the Installation Instructions), will provide the correct length of drain hose in the drainpipe or laundry tub.
Drain hose form
Is the drain hose taped onto the drainpipe? Is top of the drainpipe covered in tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure that the top of the drain is at least 39" (99 cm) high (as measured from the floor.) If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction (siphon) and the water will continue to drain out of the washer.
Apr 19, 2010 | GE Washing Machines
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
Tub won't fill with water so that we can add dye for dying clothins; Water runs and drains, won't fill tub
Assuming the motor isn’t running during fill the water is siphoning out and can be caused by a few things.
  • The drainpipe to your house may be too low and you either need to extend the pipe up above the top of the tub or run the drain hose from your washer up high.
  • Someone may have taped the drain hose from the washer to the drainpipe to your house to stop the water from backing up. To fix this either clean out the drainpipe to your house and remove the tape or install a siphon break,
  • If the drain hose from your washer is pushed down the drainpipe too far, this will also cause the same problem. To fix it just pull it out to within about 6 inches of the end of the drainpipe.
Sep 07, 2009 | Washing Machines
Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
May 30, 2009 | LG WM0001HTMA Front Load Washer
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Apr 30, 2009 | Washing Machines
Drainpipe leaking
Hi Mary, I'm going through similar experiences with my new Whirlpool which I learned to hate. I'm not an expert, however, I learned a thing or two about washers recently. Your problem could be related to one or two things: The drainpipe hose should not be placed more than 8" in length in the drainpipe as it creates a siphon effect. Also, the new washers are designed to spin fast, thus higher water pressure exiting into the drainpipe. If your drainpipe is clogged up for some reason and cannot handle the high water pressure, that may also create a problem. This can be solved by using some Draino in the drainpipe. Hope this helps.
Feb 03, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WJSR1070A Top Load Washer Logo
423 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
