Question about Kenmore Washing Machines
Our machine, Kenmore top load 823 80199, makes a noise in the agitator cycle. This is "clanking" sound which can change in pitch without an apparent change in wash cycle. It's quite lud, sounds like two mechanical parts not meshing or hitting against one another.
  • Robert Yale Oct 23, 2010
    I appreciate the solution above. I've ordered and received the "Drive Block" and found a wrench that will fit the spanner nut. However, the nut seems to be extremely tight (frozen). I've applied liquid wrench and let it sit, but still can't get the spanner nut to free up. Any ideas before I break something?
    By the way, I assume this is a standard right hand thread.
    President:
  • 2,468 Answers
You need to remove the dispenser cup and then remove a 7/16" bolt out of the top of the agitator to remove the agitator,under here there is an aluminum piece at the top of the wash basket with a spanner nut on the top holding it,remove the spanner nut and this will let you remove the wash basket,then remove this aluminum piece called the "Drive-Block" it will be worn on the edges and is letting parts slip by each other rather than meshing,this is your noise
Posted on Oct 04, 2010
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore top loader washer noisey agitator
it sounds like the gear dogs in the agitator. pop he top of agitator and check. its a easy repair.
Aug 28, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
26 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
