Question about Hoover Washing Machines
How do i remove the agitator from my hoover 800el
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: removing agitator hoover 800EL
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
SOURCE: hoover 800el not spinning
hi all, I have a hoover 800el washing machine and it's making a clicking/ratchet noise. any idea what's causing it?
Kind regards
Louis
Posted on Feb 15, 2011
Hoover 800el doesn't stop filling up with water. It just overflows. Recently transported if that helps?..??
it is possible that during transportation , the tub moved excessively and pulled the small hose off the tub that is connected to the water level solenoid
check around the tub for a small hose that goes to the control panel
Feb 09, 2016 | Hoover Washing Machines
Hoover 800EL Top loader will fill and empty but will not spin? Making a whirring noise like it is trying to?
Try replacing the large capacetor. This is called apon to give the motor the kick it needs to go into spin. For reference I include a picture to help you locate it.sparkyuiop.jpg
Apr 06, 2011 | Washing Machines
How do I remove the agitator in a Hoover 500MD machine?
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Aug 25, 2009 | Washing Machines
Removing agitator hoover 800EL
Jan 03, 2009 | Washing Machines
I have a top loader hoover 800EL,cold and hot water is coming very slow , I am suspecting the solinoid valves is it easy to replace them ?
when you put it on warm does it do the same thing?see if you can hear the solinoids ,they sould not be loud if they are they are bad,is your water presure ok?the valve is easy to replace it has to leads and alittle feed hose,just remove from back of water,(2 screws and replace)mike
Sep 05, 2008 | Hoover Washing Machines
Object caught beneath the adigator
Remove the fabric softener by pulling and pushing to one side.
Once removed, there will be a half inch bolt that holds the agitator to the transmission shaft. Loosen the bolt and the agitator will lift off.
Older Hoovers have a set screw near the middle of the agitator.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Jun 21, 2008 | Hoover Washing Machines
Hoover 800el not spinning
Kind regards
Louis
May 18, 2008 | Washing Machines
Need to remove agitator on my hoover 500m washing machine
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
Mar 12, 2008 | Hoover Washing Machines
Washing Machines Logo
37 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
