Question about LG Washing Machines
Won't turn on WT-H750/ WT-H755 - LG Washing Machines
2 Suggested Answers
  • 5186 Answers
SOURCE: lg washer manual
LG has the manual on their product support page: http://www.lg.com/au/support-product/lg-WT-H750 . Scroll down to the Manuals & Documents section to find the link to the PDF version of the manual. The link uses Javascript to download for you.
I hope this helps.
Posted on Mar 25, 2014
My lg wt-h750 wont spin or drain..
the pumps clogged or the drain pump is bad,the washer won't spin until all the water is drained out.also that model number doesn't show up,open the door to the washer look around the opening where you put the clothes in and you'll find the model number there
Nov 11, 2017 | LG Washing Machines
Series 8 remote control turns connected devices on, but not off
Try different codes. Sometime this happens with universal remotes. They just don't work all the features.
Aug 27, 2016 | Samsung Televison & Video
Keeps blowing fuses
Try using higher Amps fuse.
Oct 13, 2014 | Washing Machines
I have a spider box yerfdog 3206 wt i believe 150cc howhit engine. Won't start solenoid clicks but no power to starter. even direct power to starter wt solenoid bypassed starter won't kick in ? I have
this sounds like the starter is no good that`s why you get a click noise and why bypassing the solenoid it won`t turn over. the armature must be drawing more amps than what can be supplied.
Sep 21, 2014 | Cars & Trucks
I have no power to the display board on my washing machine, is there a fuse somewhere, a reset procedure, or am I looking at replacing the PCB's
Under the machine inside the cabinet, should be
a diagnostic manual, taped up there, hiding in a bag
You may very well have to replace the control board,
if all tests pass
You have to be able to use a volt meter on live circuit
boards & back probe the connectors, as you do to
test a car
Aug 15, 2014 | LG Washing Machines
Lg washer manual
I hope this helps.
Mar 25, 2014 | Washing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
HANSOL MODEL H750 MONITOR. WHEN I TURN POWER ON, IT DISPLAYS THE SCREEN FOR A SECOND THEN GOES BLACK. IF I TURN POWER OFF AND ON IT DOES THE SAME THING. THE GREEN POWER BUTTON LIGHT STAYS LIT THE ENTIRE...
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 15, 2010 | Hansol H750 17" LCD Monitor
Washing Machines Logo
119 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
