Question about Dual XD-6200 CD Player
How do I get aux. off the front of my xd6200 200 watts?
How do i get my speaker to work at high volume with out them cracking,popping destort
If you are using the factory installed speakers they aren't made for the wattage output of your receiver. Factory stereos only put out about 5 to 10 watts. If you want to play it really loud you need to replace them with speakers that have a higher wattage that what your receiver puts out, which is a maximum of 50 watts
Aug 23, 2015 | Kenwood KDC-248U In-Dash CD, MP3, WMA Car...
Does crunch blackmaxx take aux for iPhone?
The amp is a discontinued model, but I do think I found the specs on it. It will produce :
350 Watts X2 @ 4 ohms
700 Watts X2 @ 2 ohms
1,400 Watts X1 @ Bridged at 4 ohms
It is designed to be ran inline between your stereo and a set of, or a single, sub woofer.
This could be a significant amount of work for a beginner in car audio, but it can be done.
I would do a little research and decide if you want to use this amp. Join in on forums like http://www.caraudio.com/forums/forum.php, and http://mobileaudioforum.com/forum/forum.php to learn what can be done, and how to do it. good luck.
Jan 19, 2014 | Crunch Car Audio & Video
I just purchased a 250W Radio Shack PA amplifier. Everything seems to work fine but I can't figure out how to connect a an auxiliary device or CD. There is only one jack for CD/AUX and whatever I...
I had this problem to the only stereo rca input I could find was the top red and white. Everything else is mono, I'm currently working with 1.so if you have any advice please let me know.
Nov 15, 2013 | Radio Shack 250 Watt PA Amplifier...
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
I recently bought Philips DSP 2500 Home Theater ... i dont have a cd player nor any dvd players. i want to connect it to my pc or my cellphone through aux .... so any sollution 4 this .... m planning 2...
hi! i am the computer expert i will solve your problem , just buy 4nos. 3.5mm jack(without wire connected) . Buy 3meter wire and solder it with one for pc and other 3 for the home theatre.
For more information contact: athibanbirla@yahoo.in, billa_2010@rocketmail.com, rathiban1998@yahoo.in, sachin_vvb@in.com, Ph. no +9104522381424 .
Got It
Oct 25, 2010 | Philips MMS 460 - PC multimedia home...
Hello again. Sorry to say my knowledge is lil... I want to replace stock deck. Here is the stuff i want to put in it. Could you take a look and give an opinion if maybe i cant get away without putting a...
ok as for the deck just get the wiring harness for your car so you dont have to cut the old one out and that would eliminate the need for a wireing diagram with that done you should be able to hook all speakers you want to the stock spot so for a tweeter just hook it up with the door speaker there arnt any extra cords....you will only need a amp for a subwoofer unless you choose to put your mids and highs on one and if you didnt want to change your deck hook up the tweeters would be the same way hope this helped
Mar 30, 2010 | Car Audio & Video
No pwer to front aux outlet
Most newer vehicles have aux outlets that can only handle so many watts and do go out if overloaded. If the fuse is good, pull the outlet out and check the hot wire for power. If the wire is hot the outlet needs to be replaced. Go to Autozone orAdvanced Auto and purchase a replacement outlet either in the "Help" section or in the Accessory aisle.
Jun 27, 2009 | 2004 Saturn VUE
Auxillery in question
yes you can hook up your mp3 to an aux input on a stereo not sure what you mean by converter typically it is done through a 3.5mm - 3.5mm standard audio cable. and in order to do this your reciever must have an aux input of course and if so then you can toggle the mode of input by pressing the Mode or button that switches from radio to cd etc or consult with your users manual to find out how to switch and if aux input method is supported
Feb 15, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Adding a turntable
Do you already have a turntable you want to add, or you want to purchase one? Sony makes a turntable with a pre-amp built in, so all you do is plug it into either auxiliary input. It will play everything but 45s, I believe. Runs around $100 here.
Jan 17, 2008 | Audio Players & Recorders
Dual XD-6200 CD Player Logo
64 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
