Question about Radio Communications
Need a code for bluetooth instalation - Radio Communications
    Problem Solver:
  • 5 Answers
Tried the defaults? Quoted from wikipedia:
http://en.wikipedia.org/wiki/Bluetooth
"Limited input devices: The obvious example of this class of device is a Bluetooth Hands-free headset, which generally have few inputs. These devices usually have a fixed PIN, for example "0000" or "1234", that are hard-coded into the device."
Posted on Oct 04, 2010
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Dont know how to install my bluetooth
need to find setup then pair your bluetooth following the instructions, if when asked for pass code and your not sure enter 0000. the phone and bluetooth will do the rest.
Jan 16, 2011 | Cell Phones
I need the code for bluetooth
In my box it says it is 6-0-0-0. hope this helps
Jan 02, 2010 | Polaroid PoGo Digital Photo Printer
Installing bluetooth
You need to power on the bluetooth headset, make sure that it has a solid LED light on it. Power on the phone and go to the bluetooth settings, search on the headset, it will ask you to enter a pass code, just enter 0000 that is the default code for that.
Jul 07, 2009 | Cell Phones
My model # hfblu-s1 bluetooth needs a passkey to install
0000 or 1234 are usually the default codes for all bluetooth devices
Jun 02, 2009 | Plantronics - Bluetooth Headset Plus Base...
Bluetooth connection to my LG Renoir KC910
Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
Look at phone enter same code, 0000, when prompted and hey presto all will work.
Hope this helps
Regards
Max
May 01, 2009 | LG KC910 Renoir Cell Phone
Bluetooth not working after OS re-install on Lenovo 3000 Y500 lap
if you install xp then find out the xp drivers in www.lenovo.com > select country > support and downloads > model number> etc. After downloading file >install the driver > after installation reboot your computer > after machin on you just switch on the wifi or bluetooth switch (near you laptop hinzes) and try it.
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Instructions
Hi Deborah!
First of all you need to activate the bluetooth on your phone, after that turn on your headset, now get in the bluetooth menu on your phone, select search for bluetooth items, your phone will find your headset and it will ask you if you want to connect to it, select yes.
Many headset have a code, that code is neede to connect to the phone. if your headset have one the code should be in the manual that came with the headset. If your headset dosent have or need a code it will connect to your phone as soon as the settings is done on the phone.
Good luck
Nic
Feb 28, 2009 | AT&T LG CU515 Cell Phone - Black
Lose passcode
0000 is the default pass code for most bluetooth devices.
-WN
Aug 28, 2008 | Motorola Mobility Bluetooth Hands Free...
HOW DO I SET UP CELL PHONE TO USE IN CAR?
OK - If you are getting the SIG instead of Phone connected in the X Type - You need to enter the code - for the 2007 X Type, the Code is ##3#*# - Which should then say waiting and finally SIG ****** which means it is connectable - To pair your phone, goto bluetooth and pair device, wait until the Jaguar is found. When prompted for the numerical code it is 1313
Jul 07, 2008 | 2002 Jaguar X-Type
Radio Communications Logo
1,005 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
