Question about Brother Office Equipment & Supplies
Installed new blk ink cart and others are all o.k. Will not print black at all - if I use the color button or try to print from the computer in color, words come out very light and other colors are not bright and sometimes words do not print at all. Is a new MFC-495CW printer. Was working fine to can't print.............Thank you!
    President:
  • 1,335 Answers
I assume that you inserted an new OEM black cartridge. If you are using aftermarket of refilled cartidges, change to an OEM cartridge.
- Press on the printer
- Press of and select
- Press of to choose , or
- Press
- The machine cleans the printerhead and goes back to the Ready screen when finished.
If you clean the head 5 times and things don't improve, the printer should be serviced at a printer service center.
If you are using aftermarket or refilled cartridges the ink is typically not up to manufacter specifications and can gum up the printheads.
Posted on Oct 04, 2010
Why wont my printer print in blk?
take the black cart. out and dab on a wet paper towel, unplug printer and use q tip to clean the print head where the cartridge goes with alcohol, if that doesnt work you have a bad cartridge
Nov 09, 2015 | Office Equipment & Supplies
How do I get the printer to print when it only has the blk ink cartridge that is new and the color ink is running out. It prints everything red. What do I do?
Get new color cart. Most inkjet printers will not print anything if one of the carts is empty.
As for printing everything red, that is a different issue. Your printer setup screen in the computer may have a "black only" setting.
Nov 09, 2015 | Cannon Office Equipment & Supplies
If I only put in a black ink cart. why is it not
Yes you need colour carts in as well. Most inkjet printers ude colour to print B&W as well as the black cart otherwise it ends up looking like a photocpry.
Sep 17, 2009 | HP DeskJet F380 All-In-One Printer
Black and color ink cartrage is out installed black only
hi
go to printer driver right click on it and then go to proprties then go to device setting u will have an option of installed print cartridges and from the drop down select black and for our technician help contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Canon PIXMA MP210 InkJet Printer
Mfc 210c-new brother ink cart-blk Help test/clean instruction ??
Press the "ink" button, you will then see "test print" on the display. Press the top of the joystick like (labeled search/speed dial) wheel until the display changes to "cleaning"; then press Set. Press Set one more time to select the color black. Cleaning should start.
Mar 11, 2009 | Brother MFC 210C All-In-One InkJet Printer
New black installed; will not print in black ink. Everything else prints!
hi, it is possible that the black cart was not installed properly. Try reseating the black cart and see if it works. You can also try to calibrate the printer. you can do this by pressing the menu button then go down to calibrate printer. after that it would also help to perform a deep clean which can also be found on that same menu. then try to print. If all these fails, try to call the kodak hotline 800.421.6699
Oct 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Balck ink not working
machine needs to go into a cleaning process once you installed new cartridges to identify that there is a new one placed there.it will need 5 cleanings to do that.if you are using refillables or generic cart,then it wont properly mix up with the others causing that specific color not to print
May 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
226 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
