NEC WT610 DLP Projector Logo
Anonymous Posted on Oct 04, 2010
I have WT610 and I tried reset and holding 3D to access Cornerston/keystone for 3 seconds. What am I doing wrong shows up in menu as light gray choices in options.
  • 1 more comment
  • Anonymous Oct 04, 2010
    I have a WT610 Projector I can not access cornerstone or keystone function. I have tried reset and 3D Button clearing the settings several times to no avail. Only adjustment working is pincushion. a week ago all three functions were working. I wish to return to having all three options. When you go to the menu the options for keystone and cornerstone are light gray and not functional.
    I "Pressed the 3D REFORM button on the remote control twice to no avail" everyday for a week.
    Thanks
    Thanks
    Its great I pay good money and I get a comedian answering my problems. Believe me the reviews I am going to post will be just be what this website deserves. Forget my question and keep the money.
Anonymous
Level 3:
Genius:
  • Master 1,035 Answers
  • Posted on Oct 04, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1035
Questions
0
Helped
400044
Points
3026
Hi. You can set the color of the menu. I provided you a manual on how to do this. Please click here for the manual and scrool down to page 83.
Anonymous
Level 3:
  • Master 10,515 Answers
Anonymous
Master
Level 3:
Answers
10515
Questions
Helped
2934530
Points
31530
I am sorry, i didn't get the question completely. Which options are you trying to access?
Are you trying to clear the cornerstone screen?
If not, read page 107.
http://www.projectorcentral.com/pdf/projector_manual_2818.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Anonymous
Level 3:
  • Master 8,619 Answers
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2149161
Points
26471
Hi
Thanks for using FixYa. The issue seems to be with the lamp going bad however, please elaborate your concern so that I can assist you further.
Thanks
Rylee
  • 4 more comments
  • Anonymous Oct 06, 2010
    haha
    @wellcum: Did you get yourself checked by Psychiatrist...you really need a Dr. :)
    *The issue seems to be with the lamp going bad* for every problem OR convergence ICs, haha
    @wellcum: STFU and keep on cribbing and crying even as you are here for fun and yes make sure and see a good DR. hahaha
    Do you know any thing about dlp projector except to *replace lamp* solution? haha, go and fix washing machines.
    @welcum: Dont teach me....Have you ever seen Projection TV, Plasma, LCD or do you know what a DLP projector is...well do whatever you wan to...I am not Psycho like you...so STFU...BYE ;-)
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
2helpful
Hard reset Olympus E-520
1. Select P on the mode dial.
2. Open the card door and turn on the camera.
3. Hold down the Menu and the OK buttons at the same time for 5 seconds.
4. Olympus E-520 is displayed.
5. Release and again hold down the Menu and the OK buttons at the same time for another 5 seconds.
6. Reset has been done is displayed
7. Press the OK button.
8. Shut the camera off
Accidently set the printer HP deskjet 3050 to wrong language how do i reset?
The way was hidden somewhere in the HP solution center:
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
3answers
Tried to fix a paper jam and now I get this code C2FE0100 and the printer won't print. Unplugged it and still nothing
Found this link to reset an HP Printer:
http://www.out-of-warranty.com/how-to-reset-hewlett-packard-hp-all-in-one-printers/
Good Luck!
2answers
Oki C6100 Laser Printer drum reset - from Fatal
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
The picture on the screen is not square. one side is not the same length as the other 3.
either you have the keystone feature on, or the light tunnel is collapsing. go into the menu and reset the settings to factory default. if that doesn't help, adjust the keystone through the menu. if no change, replace the light tunnel.
Once the projector is plugged in there is no picture. The projector comes on but the lens doesnt open
Try doing a manual reset by depressing the two Keystone buttons and turn power on. Hold down the two keystone buttons for 15 seconds, then release and turn projector OFF.
Turn ON projector and it will be reset.
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
2helpful
2answers
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
1helpful
Colors in QL-711V shifted to green
Hi, I had the same problem and I wrote an email to Nu. They wrote me back that I should use the Factory reset feature which you have to go through the Factory Menu to get to. Instructions to do this are as follows. I got to the menu my first try but it has been a pain to get back to it. I hope it will be easier to access for yours.
Hope this helps
-Nate
Page 1
You will need to display a gray scale picture which varys from black to white
You will need to display a gray scale picture which varys from black to white. Displaymate 16 grays pattern is good or something like the picture to the right. 1 Press and hold SEL/AUTO and press the power button. Then release the SEL/AUTO button. 2 Press the MENU key to display the factory menu. Sencore 11 gray Pattern 3 Press the and select FACTORY2 menu. Factory2 is at the bottom. Press SEL/AUTO to select the FACTORY2 menu. 4 Press the to select AUTO COLOR. 5 Press the to run AUTO COLOR. Wait until finished. You will see the colors changing and then become stable when finished. About 10 seconds. 6 Press the and select COLOR UPDATE. 7 Press the to run COLOR UPDATE. It will finish quickly. < 1second. 8 Press MENU to exit the menu. Power off/on.
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
