Question about LG 42PC5D Television
LG 42PC5D and Rogers Cable Box says HDCP not supported when connected via HDMI cable.
NO RECONOSE EL CBLE DE LA PC NI UN CABLE USB
Posted on Nov 04, 2010
I have a bush tv and I can put 1 him cable in to connect my sky had box but when I try to put a second one in for my ps4 it's say hdcp is not supported can someone help.
Try fitting cables in a different orderor swapping the working sky conected cable to the ps4 cable. I have several hdmi and scart cables into my LG tv. Sorry but can't help more as I don't have sky or a ps4
Oct 28, 2015 | Bush Televison & Video
Anyway of upgrading TV to support HDCP? Will not support HDMI w/o it/
look on ebay for an adapter try "HDCP to HDMI adapter" as a string i wont look but i can bet your not the only one
and some guys are good to solve simple wires and balance issues
Nov 30, 2014 | LG Televison & Video
My tv is saying not supported format on hdm1
hey some hd tvs are unable to to support the high band width digital content protection(hdcp) therefore if hdcp which is a digital rights protection management system that protects copyrighted content when connecting to electronic components with either HDMI and DVI,So checkon tv settings to allow secure connection and make sure you chose HDMI/DVI in set picture format on cable box general setting and try to reboot the cable box,wait for clock to appear and start the the tv.
Oct 27, 2012 | Televison & Video
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
DVI Alert, your HDTV does not support HDCP. what does this mean? Please use YPrPb component connection to watch
Ok so, I was having the same exact problem but I got mine to work.
Make sure you have your HDMI cable is connected from the TV and cable box....
1)Turn off your tv and reboot your cable box (my cable box was rebooted by pushing the following buttons AT THE SAME TIME: "info," "vol ," and "vol-").
2)Once your cable box reboots completely, power it and the TV on...
3)Push your INPUT button on the actual TV REMOTE. Give it a couple of seconds and then use your CABLE BOX REMOTE to begin switching the channels. Your HD channels will be in the 600's if you have the same cable company as I do.
Hope this helps...it worked for me
NOTE: Your COAXIAL should only be plugged in from the cable outlet on the wall to the cable box. Your HDMI cable will be the one to plug FROM the CABLE BOX to the TV
Aug 08, 2010 | LG 42LC2D 42 in. LCD HDTV
How to turn off HDCP on 42PC5D
HDCP is detected and therefore automatic. You can pass video and audio via HDMI without HDCP protection IF the video and audio are not protected. If the content is protected, you will not be able to view or hear it without HDCP. So the best answer would be... by passing unprotected content to the TV. You can't just shut it off, it's part of the copy protection scheme. I hope this was helpful.
Apr 16, 2010 | LG 42PC5D Television
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
324 people viewed this question
Computer Repairing
Computer Repairing
