I can not find a replacement remote control for the Advent TV/DVD - model # DV2418A. The buttons on the unit no longer work, so a remote is necessary. The remote type is: RC-B01-0B. It appears that they are no longer made/available. Are there any other options? Is there a different remote available? Are there any universal remotes that are compatible and do not cause trouble? Thanks, Chelle-marie
  • 9 Answers
SOURCE: jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Posted on Jan 06, 2008
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
clusterfx
  • 67 Answers
SOURCE: TV remote control sensor
yeah,it's very easy.
pull out the bottom part(where the speakers are) - they are held with plastic hooks on the inside, they are =on the left and right side and a few at the top. just pull one end and the rest will come off easily.
remove a couple of screws holding the buttons assembly and the bottom of the screen.
slide the screen carefully upwards and when you reach about half way then it will come off.
behold...the sensor is infront of you, it's a small pcb with a light sensor on it. (if you see sensors at the very top or side...they are probably focus sensors)
sure it's not the remote?
Posted on Feb 23, 2008
SOURCE: remote control not working and need programming code for cable television/universal remote control
remotes.com says oerseas item-not available?
Posted on Feb 24, 2008
SOURCE: universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
Posted on Mar 14, 2008
I had an electrical storm and my Advent TV will not turn on. Could it be fried? Is there a reset button? model Dv2418A
If you had TV on True surge protector and all other devices are still in the mix you should check out TV's power board for obvious damage or blown fuse(s).
Aug 22, 2009 | Televison & Video
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Advent tv/dvd 27 inch flat screen. Weird Cable and power and volume problem
I have read that if you unplug the unit for more than about 4 hours, it will reset to the factory settings, and that wont be a problem.
this is at:
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7770,1
I quote one guys fix below:
JazzyDaveNew Member Joined: November 2008 Posts: 1 View Profile
The factury remote that came with my 20" Advent lost many of it's functions. I recently purchased the Phillips Remote SRU4105WM/17 and it works perfectly with the Advent as well as my other equioment. Buy has it fo $8: http://www.buy.com/retail/product.asp?sku=208673201
Jul 02, 2008 | Recoton Advent Advent DV1418A 14 in....
Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Mar 02, 2008 | Big Button TV Universal Remote
ADVENT ( adr660)
I am trying to find a code for this advent universal remote to work on my panasonic tv, can you assist me?
Jan 08, 2008 | Recoton Advent Advent ADR-560 Remote...
Remote Control not working
Heh, I got exactly the same problem 3 days ago. Question is, is it the remote or the unit itself?
Dec 30, 2007 | Samsung DVD-HR720 DVD Recorder
Advent 27 inch flat screen
i have model dv2020a television and it is locked. i cant unlock my television. i don't have the remote i have a universal remote can u help me.
Dec 20, 2007 | Recoton Advent Advent DV1418A 14 in....
Need code or code search proceedure for Advent RC-S11-0A remote
Most Universals work similar for code search, try this on yours. [list] [1] Manually turn on the device (eg TV) [2] Press & hold Code button until indicator light stays on (or blinks on some) release Search button. [3] Press & release device button (eg TV). The indicator should blink off. [4] Point Remote at device (eg TV). [5] Press the Power button on/off down until the device turns off. [6] Press the ENTER button or OK button to save the code as soon as the device shuts off. (Suggest you have a finger on it for fast response.) Hope this works for you.
May 12, 2007 | Recoton Advent Advent RCS110A Remote...
Televison & Video Logo
Top Televison & Video Experts
