Question about Ricoh Aficio 250 Copier
The function key
Pls sir I sending from Ghana,I am having a problem on my ricoh aficio photo copy machine(Black &White).when I switch it on then the funtion key appear on the screen that I hv to call the machine servicess that is why am sending u this message if u could tell me where the problem from.u can contact me on this e-mail(tiscali200@yahoo.com). for any information
Press Yellow key once
Press 107
Keep pressed orange key till you find your screen changed.
restart the machine
Posted on May 28, 2008
  • 30 Answers
Hi whats the SC code showing up?
Ricoh aficio mo 3351 reads messege functional problem detected . SC819
unplug the hard drive and switch on machine, if the problem goes away, then plug the hard drive back in and format it with service code 5-832-001, normally works
Nov 03, 2013 | Ricoh Aficio MP 2000 Black and White...
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
I had a functional problem sc 546 with my copier Ricoh 2022
Hi mkpack,
The error code SC546 that you're getting with your Ricoh Aficio 2022is related to unstable fusing temperature. There are two possible causes for this issue. These are, the thermistor is already defective and/or the crusted toner on the fuser roller. To reset this error code (SC564) you might to follow these steps:
1. First, press the yellow clear all button.
2. Then, select 107.
3. Hold the red stop button until the machine switches to SP Mode.
4. Afterwards, press the copy SP or system SP button.
5. You have yo shut your machine off and then turn it back on.
If after doing these steps and still you're encountering the issue you might need to remove the fuser and clean it. Also, you miht need to replace the thermistors. It's the black aluminum roll in the fuser unit.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Ricoh Aficio 2022 Black and White Copier
I have a customer with an Aficio 2022 copier and she has indicated to me that the 1 touch options have dissapeared on her display. (eg. sorting, duplexing, finishing options) I tried to talk her through...
please go to user tolls - copier/documentserver feature - say 2 times next you find the copy function key F1 to F5 you can change the settings that will display in one toch options -thanks
Mar 09, 2011 | Ricoh Aficio 2022 Black and White Copier
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Toner can be wiped off after copying - smudges
Hello sir; This problem caused by fuser roller and presure roller in heating unit, you have to take apart check it out, may be bushing broken.
Feb 18, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 250 Copier Logo
111 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
