Question about Pokemon Mystery Dungeon: Explorers Of Darkness for DS
The game says "don't move your finger quite yet" and won't move to the next screen
PHONE WON'T QUIT BEEPING WHILE TALKING
I just go this phone and it is complicated. It is a Touch screen phone and the Minute Minder was on "On" I thought I was getting a message while I was on the phone because the phone kept beeping. To turn Minute Minder off do not tap the button next to it that is blank but probably means off. Slide your finger across the line where it is highlighted and says Minute Minder to the blank square. Then the "Off" will show on the line. Don't tap it won't work--slide.
Aug 10, 2012 | LG Cell Phones
My mac screen and wallpaper moves every time I touch my mouse
I think what has been done is your grandchild has accidently magnified your screen slightly. To correct this hold down your ctrl key on your keyboard and move your finger on the mouse scroll button back. Hope this helps.
Dec 16, 2011 | Apple 20" iMac Desktop
I cant work out how to move shortcut icons i.e Facebook app to a different home screen and how to delete shortcut items from a home screen?
On android, move a Icon/shortcut: press and hold the finger on the icon and drag it to where you want either on the same screen in a different spot or to another adjacent screen then lift finger.
To delete an icon/shorcut, do the same as for moving the icon but this time drag it to the 'Trash bin' symbol at bottom line/middle position of the screen: the icon should turn Red and lifting yiour finger will delete it.
It takes a bit of practice but it is quite easy and safe as you can always get the icon back from the application folder.
Hope it helps!
Sep 23, 2011 | HTC Wildfire Cell Phone
It turns on and comes onto a report problem so i send it but sometimes a report problem doesn't come up nether the less either way it starts for about 7 seconds then just freezes won't let me move...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
When i turn my dsi on and put a game in it comes on screen that there is no game in console
hold the game down in the slot for a little bit and carfully move finger(what i ment was move thumb slowly
Sep 12, 2011 | Dsi Video Game Consoles & Games
Icon very big how can i make it small
First of all try this: Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
If it doesn't help, follow the steps below and repeat the above (step 5.)
  1. Tap the "Settings" menu from the iPhone home screen.
  2. Tap "Accessibility."
  3. Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
  4. Return to the iPhone home screen.
  5. Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Apple iPhone 3G
Screen magnified and will not unlock
This might help...
ZoomMany iPhone applications let you zoom in and out specific elements. For example, you can double-tap or use the pinch gesture to expand webpage columns in Safari. Zoom is a special accessibility feature that lets you magnify the entire screen of any application you’re using to help you see what’s on the display.
Turn Zoom on or off: In Settings, choose General > Accessibility > Zoom and tap the Zoom On/Off switch.
NOTE: You cannot use VoiceOver and Zoom at the same time.
Zoom in or out: Double-tap the screen with three fingers. By default, the screen is magnified by 200 percent. If you manually change the magnification (by using the tap-and-drag gesture, described below), iPhone automatically returns to that magnification when you zoom in by double-tapping with three fingers.
Increase magnification: With three fingers, tap and drag toward the top of the screen (to increase magnification) or toward the bottom of the screen (to decrease magnification). The tap-and-drag gesture is similar to a double-tap, except you don’t lift your fingers on the second tap—instead, drag your fingers on the screen. Once you start dragging, you can drag with a single finger.
For best results using three-finger gestures, relax and let your fingers touch the screen naturally.
Move around the screen: When zoomed in, drag or flick the screen with three fingers. Once you start dragging, you can drag with a single finger so that you can see more of the screen. Hold a single finger near the edge of the display to pan to that side of the screen image. Move your finger closer to the edge to pan more quickly. When you open a new screen, Zoom always goes to the top-middle of the screen.
Jul 11, 2009 | Apple iPhone Smartphone
Ps3 wont play games or movies but lets me play a music cd
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-4 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i Afrikaans BUT PLZZZ RATE ME.thanks
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
Pokemon will Not Set Up
DO NOT breathe or move ur thumb/stylus after a few seconds it'll work
took me a while 2 figure out that it knows if u move or breathe
Dec 25, 2008 | Pokemon Mystery Dungeon : Explorers of...
DS will not move past aura selection.
Keep ur thumb or stylus COMPLETELY still and DO NOT BREATHE the microphone will sense if u do and make u wait longer it took me a while 2 figure that out
Pokemon Mystery Dungeon: Explorers Of Darkness for DS Logo
164 people viewed this question
Top Pokemon Video Game Consoles & Games Experts
NOEL
NOEL
Are you a Pokemon Video Game Console and Game Expert? Answer questions, earn points and help others
