Question about Nintendo Wii Console
Can't get the remotes to work, chnaged the batteries but not sure how to reset the remotes
  • 37 Answers
Take off the battery cover on the remote, then the little flap on the Wii. You should see a red button on both the Wii and Wiimote. Push them both at the same time, hold them close together. Once the Wiimote stops flashing, you should be good to go!
Posted on Oct 05, 2010
2007 chevy cobalt i just chnaged the oil and now its telling me to chnage the oil soon
Press the INFORMATION and RESET buttons on the DIC at the same time to enter the personalization menu. Press the INFORMATION button to scroll through the menu until OIL LIFE RESET is displayed. Press and hold the RESET button until the DIC display shows ACKNOWLEDGED
Nov 17, 2016 | Chevrolet Cobalt Cars & Trucks
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
We got the moon in your room and can't get it to work. Chnaged the batteries twice, made sure the moon was on, pushed all the buttons and nothing. please help.
Well.. without going into great detail
Assuming you placed the batteries in the Moon.. and switched it to ON..
A couple of things.. first.. the room lights must be out.. it has a sensor so it won't illuminate with lights on.
Also.. I know it's redundant.. but make sure the batteries are oriented correctly +/- per instructions in both moon and remote control.
And finally..the"Moon" must be hung on a wall.. in a vertical position using one of the three mounting holes.
http://unclemilton.com/in_my_room/moon_in_my_room/
Best of luck!
Apr 30, 2011 | Uncle Milton Moon In My Room
Remote control rmt b101a stopped working, changed batteries, same thing; did reset by pressing power, TV i/o and vol- simultaneously, still not working. Help!
Make sure that the Remote is operating in a range of 3 to 10 feet away from the unit.
Point the Remote directly towards the Remote Sensor of the Device.
Remove any obstacles that may be in the path of Remote and the Sensor.
Make sure that no interference is blocking the Remote to operate normally. Do not expose directly to Sunlight, bright florescent lights etc.
Try resetting the Remote by removing the batteries from the Remote control, press every button twice, and then re-install the batteries after 1 minute.
Make sure that none of the buttons on the Remote control is jammed.
Install fresh alkaline batteries in the Remote, do not use rechargeable batteries.
Make sure that the batteries are inserted by matching the polarity (+ & -).
Try resetting the Blu-ray Disc Player with which you're using the Remote.
If the issue persists, after all the possible troubleshooting steps, service may be required.
Thanks for using FixYa
Dec 03, 2010 | Sony RMT-B101A Remote Control
Remote want work on tv
Make sure that you're using the supplied Remote (RMY-906) to control the TV. If so, perform the steps given below to resolve the issue.
  • Make sure that you're using batteries which are having enough charge. Try using fresh alkaline batteries.
  • Do not use rechargeable batteries in the Remote.
  • Ensure that the batteries are inserted correctly with the correct terminals by checking the + and - symbol in the battery compartment.
  • Make sure that the Remote is set to operate with the correct functions. On the remote control, press the TV FUNCTION button to re-check this.
  • Press the POWER button and other buttons to test the operation.
  • Make sure that none of the buttons are jammed in the remote control.
  • Ensure that the remote control is being used no closer than 3 feet and no further than 10 feet away from the unit. Try using the remote control at varying distances from the TV.
  • When using the remote control, be sure to point it directly at the remote sensor on the device.
  • Remove any obstacles that may be in the path between the remote control and the device.
  • Ensure the remote sensor of the device is not exposed to direct sunlight or bright florescent lights, as this can interfere with the sensors ability to receive signals from the remote control.
  • Try resetting the Remote. To reset the Remote. remove the batteries from the remote control, press every button twice, and then reinstall the batteries.
  • Try resetting the TV also to check the operation. To reset the TV, disconnect the power cord for a short period of time (approximately 1 minute), then reconnect the power cord and power on the television.
If the remote control is able to operate other devices (such as cable box, DVD Player or satellite receiver), then the issue may be with the IR sensor on the TV. If this is the case then the TV that will require service. Otherwise, the remote control may need replaced.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony KP-61S75 TV
I have a 1F81-51 White-Rodgers thermostat that keeps resetting itself back to the factory default settings. I've chnaged the batteries, but it continues to automatically reset itself after I have...
I had the exact same problem. Even pressing the Hold button does not really help, because once it resets - the Hold temperature also changes to the default.
I fixed this by replacing the 470 micro-Farad / 10v capacitor in the unit (it's the grey-colored capacitor). To access the back of the circuit board, you will need to break 2 plastic rivets holding the front of the unit to the base.
After replacing the capacitor I've not had any resets for the past 3 days (it used to reset itself every couple of hours).
Hope this helps.
Noel
Aug 21, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My JVC remote C5676 will not work with my JVC TV
Make sure you push the button for the TV on the remote first so it knows it's controlling the TV. If that doesn't work, try changing the batteries.
Best Regards,
James
Jul 21, 2009 | Televison & Video
Remote not working,
Changed batteries on remote now they will not not work Help !
Jul 02, 2008 | Aspire Digital AD-225PSC Subwoofer
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
