Question about Toshiba Satellite Pro 4600 Notebook
DVDwriter on a toshiba satellite pro 4600?
Hi out there, my toshiba lappy satpro 4600 is a little bit of old and just came with a cd reader. I'd love to upgrade to a dvd writer. any ideas how to accomplish this? no newer bios than from 2002 available, though. Regards, alex I have a DVDRW fitted which is now not working, how do I get at it to see if its just cables that are loose or so I can replace it
I've got a DVD burner installed some time ago in a Satellite Pro 4600. To do this you have to have the right settings regarding Master and Slave - as far as I can remember a Master drive is needed. To get a 6500A NEC drive running I had to solder two pins together in order to get it recognized as a Master drive on the second IDE controller; you can find a pretty good explanation at http://www.dschen.de/laptop_brenner/ (sorry, all German but perhaps the images might help). So, before you buy a new drive make sure you get one that is already set as a Master - ask your dealer! Sometimes a new firmware could do the same.
After setting the drive to Master I have used it on Linux without any problems so far...
Posted on Jun 18, 2008
    Champion:
  • 207 Answers
If it is a laptop there are not much cables in it there is a cabinate where it is fited well if u know abut device manager go into the dm and see weather the rom is been detected over there or not
is not try to unplugg and replug the rom its very easy look near the rom ull see some place to put ur thumb and pull out the rom ...do this and then let me know any ways if ur lappy recognize it u cab easily replace wd the writer
Posted on May 28, 2008
  • 426 Answers
You most likley will have to remove all the screws EVERYWHERE and rember where they came from Just remember to be VERY CAREFUL when removing the keyboard and any other covers or devices because ribbon cables are very fragile and very expensive
Posted on May 27, 2008
  • 45 Answers
You could always try using an external dvdrw drive. then there's less heat issue and easier to check cables and connections.
as for getting into to see if its a cable issue, that means takign off the whole case usually. which can be an interesting experience.
Hi there i have a toshiba satellite pro 4600 and i was wondering where the touchpad/mousepad is
Your mouse pad/ touch pad will be located under the keyboard on the front panel.
Jul 25, 2011 | Toshiba Satellite Pro 4600 Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Keystroke to recover my satpro l300
try this one first:
  • press F8 while notebook powering up
  • choose repair my computer
  • choose Toshiba recovery
if that will not work and since you have the disk, you don't need special combination keys to press. just boot to the disk by changing the boot sequence on your BIOS or in some cases, pressing F12.
Mar 14, 2010 | Toshiba Satellite Pro L300 Notebook
Downloads
This link will take you to the Toshiba support download page. Follow the instructions and prompts to search out the drivers you need by model number.
Mar 16, 2009 | Toshiba Satellite Pro 4600 Notebook
What is the power button for toshiba satellite pro 4600
hi..the power button is available on the top
of the laptop.It willl be indicated with the
red symbol on it.
check this out..
thank u..
rate me..
Feb 21, 2009 | Toshiba Satellite Pro 4600 Notebook
Satellite Pro 4600 SOFTWARE CD
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?selModel=1073792275|PS460U&modelFilter=4600&rpn=PS460U&category=&selCategory=3&moid=1073792275&os=&ct=SB&selFamily=1073768667
This is all you need, for any operating system ! If you need any more help, this is my yahoo mesenger ID : szasz.hunor
Feb 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Lost installation cd
ask toshiba to send one for a nominal fee.
Nov 29, 2008 | Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
