Question about Toshiba PA1390U1NKP Keypad
MY BUILT IN MOUSE ON LAPTOP DOES NOT WORK ONLY ON EXTERNAL MOUSE I CAN USE LAOTOP
  • 2 more comments
  • paulgrisw0 Oct 04, 2010
    your solution did not work i had to use cntrl funtion f9 and hit misc buttons then built in mouse and remote mouse worked together you can charge me if you want to thankyou......paul
    no,it did not solve the problem cntrl function f9 and hitting keys at random worked now external mouse and internal mouse works
  • paulgrisw0 Oct 06, 2010
    i did that 2 days ago on my own, thanks anyhow
    your solutions did not help i did the fn f9 2 days ago and my touch pad is enabled now what? is there a 4th option? i will be happy to pay any fee but i dont accept your solution, so you can charge the
  • 3,530 Answers
Assuming that your touchpad is enabled (hold the Fn key and press F9), do the following:
1.Power cycle your laptop. Turn it off, remove the battery, put the battery back in after 30 secs and turn it on again.
2.If this does not work, uninstall and reinstall the driver for the touch pad.
  • Go to Device Manager
  • Click on the + sign right next to Mice and Other Pointing Devices.
  • Right click everything listed under Mice and other Pointing Devices and Uninstall.
  • Go to Toshiba Support,
  • Click DOWNLOADS and choose your laptop model
  • Refine your search.
  • You will see Driver Touchpad. Click on it to download.
  • Restart your computer.
Let me know if this has been helpful and make a comment if you need further assistance.
Thank you!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Oct 05, 2010
  • Jose Cada
    Jose Cada Oct 06, 2010
    It is possible too that the connection from of the touchpad to the keyboard is loose. If you are not comfortable opening up your laptop, I suggest to take it in for a service.
    Cheers!
  • Jose Cada
    I am sorry for the misunderstanding on my part. Glad to know that the touchpad is now working.
    Thank you.
  • 2,973 Answers
The drivers for the builtin mouse may have got corrupted. Please reinstall it. Please go to Control Panel->System->HW->Device Manager->Pointing Device. Here select the mouse and delete it. Roboot. And go again to the same place and from Menu select Action->Scan for new HW. Windows will reload the drivers for the mouse.
Posted on Oct 04, 2010
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
Cq60 frozen mouse pad
Since you don't seem to want to help us in helping you, by being more detailed about your mouse, or mouse pad, problem, I will give you some general advice:
- This is a laptop, yes?
- It has one of those little areas where you can use your finger, instead of a mouse?
- Look in Device Manager, or even in the Mouse option in Control Panel, and see if you have a mouse configured for your laptop, in addition to the built-in finger pad for use as a mouse.
- If you find there are two separate devices, one for the laptop-supplied mouse square, or rectangle, with the buttons on the bottom, for use instead of a mouse, and one for an external mouse, then make sure you have designated the built-in pad for use as a mouse. If, however, you want to use an external mouse, then you do the opposite, and ensure that the external mouse is selected as the device you wish to use for a mouse, and disable the built-in mouse/finger pad software, so that you do not have a conflict.
One or the other must be primary, and the one not primary must be disabled, or your laptop must be told not to use that other one.
Apparently - again, because you gave us absolutely no details - there is a hardware conflict and the laptop doesn't know which device to use, so it is not using either, and you're stuck without the benefit of any pointing device.
All the work you need to do with device manager and control panel must be done with keystrokes, and for that you must use Windows' Help to learn which keys will do what. Usually the four arrow keys, near the numeric pad, along with Page Up and Page Down, and the Tab button, or Shift+Tab, to go backwards, are all you might need to reset things the way they need to be set.
I hope you understand that absent any details at all, the only advice you will get from anyone here, is going to be educated guesswork.
Best of luck to you.
Cheers!
-a.
Jun 16, 2012 | Compaq Presario CQ60215DX PC Notebook
Built in mouse has not worked properly from day 1. Now my external mouse won't work either. I tried a different external moue, but it doesn't work either.
Unplug everything except the power cord, including the following:
Speakers
Printers
Scanners
USB devices
Personal Digital Assistants (PDAs)
USB flash drive or other external storage devices
External Monitor
External Keyboard
External Mouse
If your computer is attached to a docking station, undock it.
Make sure the touchpad or your finger has no dirt, grease, liquids or food on it (the touchpad has to make a good contact with your finger to work correctly).
Turn the computer back on and retest the touchpad.
When the touchpad still does not work correctly proceed to step 5.
When the touchpad does work correctly, attach one external device at a time and test the touchpad to see which one may have caused the issue.
Make sure the latest driver for the touchpad is installed (you may need to use a external USB or Bluetooth mouse), for more information refer to:
"How to Use the Drivers and Downloads Website"
May 26, 2011 | Dell Inspiron 1525 Laptop
I have acer laptop model ASPIRE 5732Z suddnly inbuiled mouse stop working but usb mouse is working, whats is the problem and what is the solution.
There is sometimes a switch to disable the built in mouse/trackpad when using an external mouse, you can also check mouse properties in control panel
Jul 10, 2010 | Acer Computers & Internet
Fix left click on built in mouse
If you're talking about the touchpad, then I'm afraid that no; it's not easily replaced.  The most probable thing that's happened is the microswitch underneath the button has worn/broken.  You not only have to pretty well completely dissassemble the keyboard part of your laptop, but it's a tricky job when you get there.
The best solution is to get an external USB mouse and use that.  It's a bit late to tell you this, but using an external mouse to take most of the wear is the best thing to do anyway...save the touchpad for when you have no other choice.
Mar 07, 2010 | Gateway M-7315U Notebook
Suddenly my mouse and roller bar stopped working
Fn + F7 (or thereabouts)
Usually enables/diables built-in trackpad for those who use an external mouse but keep accidentally moving the built-in trackpad while typing.
Nov 18, 2009 | Acer Aspire 5610-4648 Notebook
Dell Studio 15 laptop mouse does not work at start up.
It sounds to me like the mouse buillt into your laptop is conflicting with the Dell external mouse. If you go into control panel and click on mouse, you can disable your built-in mouse. Restart your computer with the USB mouse plugged in and see if that does the trick. I would be surprised if it does not. On the off chance it doesn't work, you will have to enable your built-in mouse and we can check to see if there are any additional conflicts happening through your hardware profiles in the system area of control panel.
Jun 21, 2009 | Dell U0636 Mouse
I have a hp paVILLION DV 9000 laptop,have been using at work station so been using external wired mouse.no all of a sudden i have no curse controll at all with external or in built mouse.cant get control...
Check the touchpad on/off button at the top of the mouse touchpad on the laptop, it's small and can easily get turned off by accident and you will think your mouse has quit working. There is usually an indicator light next to it. I'm not sure but on your laptop I believe it may be a blue light when the button is on and turns orange when switched off.
Jan 20, 2009 | HP Pavilion dv6000z Notebook
Toshiba PA1390U1NKP Keypad Logo
137 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
