Question about Zanussi Ovens
An older zanussi model 290120 No, p120988/25 needs a new thermostat can you help?
  • 2,272 Answers
You can buy new thermostat for your zanussi product from:--
http://www.4zanussi.co.uk/cgi-bin/catalogue.pl?section=108061
OR http://www.easyspares.co.uk/products.asp?c=62&c2=144
OR http://www.comparestoreprices.co.uk/spares/zanussi-thermostat-140-deg-pn-1250024005.asp
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 04, 2010
Oven wont heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 06, 2011 | Zanussi Ovens
Oven overheats despite replacing the thermostat [which you can hear clicking on and off whenyou move the dial, and you can see the orange light come on and then go out again]. What's interfering with...
Hi.
If the thermostat you are referring to is the temperature sensor probe located inside the oven cavity, then the problem is the oven electronic control or a short in wiring. Older model have also a relay-controlled power board that must be checked.
If the temperature probe has not been replaced yet, replace or test the temperature probe. If there is temperature runaway, then the probe is usually shorted and will read low impedance even at high temp.
Regards.
Ginko
Jul 14, 2011 | Zanussi Ovens
Fan oven not heating up
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
The oven was on and working..then the electric tripped and all power went off...after putting the switch back up on the fuse box everything on the oven started working but it does not get...
If this helped like us on facebook please How to Video Tutorials on Domestic Appliances
Mar 04, 2011 | Zanussi ZBF260 Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Fixing thermostat on oIder Hotpoint Double Oven
Hello, there is no fixing the thermostat although some of the older thermostats could be calibrated by using a very small flat head screwdriver in the shaft of the thermostat if there is no opening for a tiny screwdriver in the shaft then it cannot be calibrated. If you have to change the thermostat contact your local parts department have the model # handy if the original is not available ask about universal oven control replacement parts. Good Luck
Dec 21, 2008 | Zanussi ZDQ895 Electric Double Oven
Oven not working
Dec 19, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi zbf 760 (9 yrs old now)
How to Video Tutorials on Domestic Appliances How to Video Tutorials on Domestic Appliances
Sep 24, 2007 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
102 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
