Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Window resume loader
When i switch off my computer its ok but when i on it again it is showing messgage of "windows resume loader failed The last attempt to resume the system from its previous location failed, its asking me to resume again.plz help me i m using acer pc with vista os .plz help me a.s.ap.
    Scholar:
  • 110 Answers
Windows Vista doesn't shut down the machine by default when you press the power button. Additionally, if you look at the bottom of the start menu you'll see this:
The button on the left, highlighted here in bronze, does NOT turn the machine off in Windows - it suspends it, which requires power. When the battery runs down, the power goes out and you get this message the next time you start up.
Some laptops also indicate suspend mode by flashing the power light.
Happily, if you click on the little right facing arrow a menu pops up, one of the options of which is "Shut down" and this will bring Windows down properly and fully.
You can also change the function of the power switch (which defaults to suspend, NOT shut down) by going into the power options from Control Panel:
Selecting one of the above options will allow you to set the power button and closing the lid to turn the machine off fully, not suspend it.
Posted on May 27, 2008
There have been alot of problems reported with windows vista including getting alot of viruses i myself have experienced alot of the problems the best solution is the same thing i have been doing with other peopels computers and reinstall windows xp
Why does window updates fail?
could be a bad update prior to the failure.Suggest going to programs and features and selecting show updates . Then remove two last updates and then try to update it again
May 02, 2017 | The Computers & Internet
My button F3 works and button V when my laptops shoes Window Resume Loader
What are you trying to do when it shows up? It may have a problem with Windows files. Try to shut it down totally and boot it again,
Jun 04, 2014 | Acer Computers & Internet
My laptop screen goes black after being turned on. First the windows emblems comes up and it says resuming windows, then goes completely black.
Try holding down the power key to force it to power off. Power it back up again and you should get the Windows Resume Loader with the following options "Continue with resume" and "Delete resume data and continue with startup". I can't remember the exact wording of the options, it may be different but you need to select the later or second option "Delete resume data and continue with startup".
Sep 07, 2013 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Got a boot up problem. Windows loads for about 2 seconds then sends me the windows resume loader screen and then when I click continue with system resume it goes to the blue screen, loads windows for 2...
I'd suggest that your memory or hard drive is going bad.
RAM issues are normally accompanied by a blue screen with a STOP 0xxxxx00038 (example) type of message or a Page fault type error, which is caused when windows loads, and the full potential of the Ram module is used, highlighting the fault with the module.
Try substituting a RAM module and see if this stops the problem, then, if you get it running, download MEMTEST and run it for an hour to check the ability of the ram to read and write information.
If the ram is ok, the fault may be with the hard drive, a faulty drive will not read the sectors that Windows is installed on and this might account for the constant rebooting. If you can remove the drive test it externally using a docking station or slave it to a working computer and download HDD check, which will test for any performance drop or bad sectors.
If you think that the Ram and HDD are ok, then obtain an external USB DVD drive and try a repair after setting the bios to boot from the USB drive
Aug 16, 2011 | Acer Aspire One D255-2670
Lap top shows a screen saying "Computer is locked" just clicking on the box, makes it go to the next screen. just a hasle doing this every time.
In order to remove the lock screen after resuming from screen saver, sleep, standby, and hibernate, please follow these steps.
Windows Vista/7
1. Right click on an empty space on the desktop and select "Personalize"
2. On the far right of the Personalization window is the option for Screen Saver. Click "Screen Saver".
3. Unselect "On resume, display logon screen".
4. Click "Change Power Settings".
5. Click "Require a password on wakeup" on the left hand pane.
6. Select "Don't require a password" and select Save changes.
Windows XP
1. Right click on an empty space on the desktop and select "Properties"
2. Select the Screen Saver tab.
3. Unselect "On resume, display Welcome screen" or "On resume, password protect".
4. Select "Power".
5. Select the "Advanced" tab.
6. Uncheck "Prompt for password when computer resumes from standby". Click Apply, then OK, and then OK again.
Good luck, please post back if you have any difficulties, and thanks for using FixYa.
Apr 11, 2011 | Computers & Internet
Computer is making a loud noise when i start up and giving a start up failed error. It says Windows resume loader. The last attempt to resume from its previous location failed. Attempt to resume again? use...
Unfortunately, it sounds like your hard drive has crashed. You'll have to change your hard drive or take it to someone who can replace it for you. If you have a bunch of preinstalled software but don't have the disks to reinstall them it might be cheaper to replace the computer.
Mar 24, 2010 | HP Compaq Presario F756NR Notebook
My vostro 1760 laptop shows power but a black screen Also I cannot switch it off I can hear it running but nothing I do will switch if off I was working on it & didnt realise the battery was at a...
How do you switch off you laptop? Try this press and hold on the power button for about 5 seconds. So it won't boot to windows? When you turn on the laptop and you see the dell logo keep tapping on F8 then try booting in safe mode, if fails do F8 again then last known good configuration, if fails do F8 then startup repair, if fails do F8 then system restore, if all fails reinstall os. but before all these steps try to test hdd first. make sure laptop is off. press and hold on the Fn key then press power button. Run the PSA test and once it finish it will show you some errors code like 0142 -0146 means hdd needs to be replaced.
Sep 23, 2009 | Computers & Internet
DELL inspiron 6400 not switched on
This is a no boot issue. Youre saying that you can perfectly run the PSA diagnostics but doesnt load Windows rather it stays on black screen, meaning the boot loader of Windows failed to load. You need to reinstall windows on your computer
Jun 02, 2009 | Dell Inspiron 6400 Notebook
There is a known corruption problem with Windows Vista's resume operation, but I've not yet confronted it on a laptop. On a desktop the problem occurs when a USB keyboard is in use, and the resolution is to unplug it and make sure that you're using a standard PS/2 keyboard instead, but I am not sure if this will work on a notepad. It depends if the notepad scans for an external keypad at boot time. Try plugging in an external keyboard before you turn the power on and see if that works.
If it doesn't work, I'm not sure what to suggest. People who have had this problem appear to have tried everything from resetting the BIOS to reformatting the hard drive. If you try it and report failure I'll investigate the matter further.
May 28, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
437 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
