Question about Fisher and Paykel DEGX1 Electric Dryer
How do you make sure that the full 220 are going to the dryer? Is it possible that there used to be 220, but now are only 110?
  • 32 Answers
First get an VOM, if you don't know what this is have someone that does help you, and check the voltage at the outlet. Then go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem.
Posted on Oct 15, 2010
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
Dryer is not blowing heat
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Aug 17, 2014 | Kenmore Elite Oasis 7808 Gas Dryer
Replaced the fuse in dryer still no heat, but dryer tumbling well, what can be wrong
Jul 05, 2014 | Kenmore 600 7962 Dryer
Kenmore gas dryer model 110 775 42600 won't heat what is wrong
Jul 04, 2014 | Kenmore 500 6952 Dryer
Why is kenmore he4 dryer not heating
Jun 25, 2014 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 80 series does not heat
May 17, 2014 | Kenmore Dryers
Cleaned out duck work now blows cold air
May 15, 2014 | Kenmore Dryers
My kennmore dryer model # 11062912100 won't heat up what is the possible cause?
May 05, 2014 | Kenmore 62602 Electric Dryer
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
