I am installing a gas heater in my workshop, I have to have a service switch installed as well . Can I run normal 14/2 wire from the panel to the switch then use the BX 14/2 or do I use BX all the way.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. You can use 14/2 wire to the furnace from the panel box and then use the bx wire from the switch to the furnace.
Posted on Oct 04, 2010
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
My Boch 24ES Highflow Hotwater is showing Code 14 and only runs for i minute then shuts off
Code 14.
What water heater do you have?
Question posted under tankless Bosch, but these error codes start with a letter.
Rheem/Richmond etc Tankless has error code 14
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Paloma-Tankless-Error-Codes.pdf
Call tankless service technician.
Ask technician how much it costs to have recommended yearly service.
Or install whole new tank-type gas water heater yourself for $350 from local box store, and avoid the entire headache, then sell tankless online for parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Water Heaters
A2 code appears and there is no hot water in the house. what should i do?
Problem with overheat cutoff. Press reset button on the control panel.
Before calling service technician, open following link for Bosch troubleshoot resources.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Recommend that people not install tankless water heaters, or heaters they cannot repair themselves since all costs are energy.
Aug 04, 2012 | Bosch Water Heaters
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
I just purchased a Master Temp 400 for my pool. The installer is telling me that the normal gas line pressure going into my home is 4 ounces of pressure. I also have a gas 17KW generator and a gas...
The owner's manual and installation manual details exactly how this is suposse to be install. You shoul have a pressure going to the heater of 14 WC (Water Column - more on that elsewhere). if you have already installed a high pressure regulator, then all you need is to send a line from that high pressure line closer to whwre your heater is installed, at that point you will install a low presurre regulator and should be able to adjust the pressure required by your heater. That is what they call a two stage gas regulators installation
Dec 05, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Looking to replace heater core
Cherokee, Grand Cherokee, 1999-2005
Removal & Installation
  1. Disconnect and remove the negative battery.
    CAUTION After disconnecting the negative battery cable, wait 2 minutes for the driver-s/passenger-s air bag system capacitor to discharge before attempting to do any work around the steering column or instrument.
  2. Drain the cooling system into a clean container for reuse.
  3. Remove the instrument panel by performing the following procedure:
    1. Turn the steering wheel in the straight-ahead position.
    2. Remove the knee blocker from the instrument panel.
    3. Remove the steering column; do not remove the air bag module, the steering wheel or switches from the steering column.
    4. From under the driver-s side of the instrument panel, disconnect the following items:
      Instrument panel wiring harness connector from the 100-way wiring harness connector at the left side of the inner panel. Side window demister hose at the heater/air conditioning housing demister/defroster duct on the driver-s side.
    5. Remove the glove box.
    6. Reaching through the glove box opening, disconnect the following items:
      Two halves of the heater/air conditioning system vacuum harness connector. Instrument panel wiring harness connector from the heater/air conditioning system wiring harness connector. Instrument panel wiring harness connector from the passenger-s side air bag module wiring harness connector. Side window demister hose at the heater/air conditioning housing demister/defroster duct (passenger-s side). Two halves of the radio antenna coaxial cable connector. Two instrument panel wiring harness connectors from the passenger air bag ON/OFF switch wiring harness connector. Passenger-s side air bag ON/OFF switch wiring harness from the retainer clip on the plenum bracket that supports the heater/air conditioning housing just inboard of the fuse block module. Two lower passenger-s side air bag module bracket-to-dash panel nuts.
    7. Remove the upper cover from the instrument panel.
    8. Remove the 3 instrument panel-to-door hinge pillar screws.
    9. Remove the 4 upper instrument panel-to-dash nuts.
    10. Using an assistant, remove the instrument panel from the vehicle.
  4. If equipped with air conditioning, discharge and recover the air conditioning system refrigerant.
  5. Disconnect the refrigerant lines from the evaporator. Plug the refrigerant openings to prevent evaporation.
  6. Disconnect the heater hoses from the heater core tubes.
  7. Disconnect the heater/air conditioning system vacuum supply line connector from the T-fitting near the heater core tubes.
  8. In the engine compartment, remove the 5 heater/air conditioning housing-to-chassis nuts. If necessary, loosen the battery hold-downs and reposition the battery for access.
  9. Remove the cowl plenum drain tube from the heater/air conditioning housing stud; it-s located behind the cylinder head on the cowl.
  10. From the bottom of the heater/air conditioning housing, remove the floor duct.
  11. On the passenger side, remove the heater/air conditioning housing-to-plenum bracket screw.
  12. Pull the heater/air conditioning housing down far enough to clear the defrost/demist and fresh air ducts, then, rearward far enough to clear the mounting studs and the evaporator drain tube to clear the dash panel holes.
  13. Remove the heater/air conditioning housing assembly from the vehicle.
  14. Remove the heater/air conditioning housing upper case.
  15. Lift the heater core from the lower half of the heater/air conditioning housing.
To install:
  1. Assemble the heater core into the lower half of the heater/air conditioning housing.
  2. Install the heater/air conditioning housing upper case.
  3. Install the heater/air conditioning housing assembly to the vehicle.
  4. On the passenger-s side, install the heater/air conditioning housing-to-plenum bracket screw.
  5. At the bottom of the heater/air conditioning housing, install the floor duct.
  6. Install the cowl plenum drain tube to the heater/air conditioning housing stud; it-s located behind the cylinder head on the cowl.
  7. In the engine compartment, install the 5 heater/air conditioning housing-to-chassis nuts.
  8. Connect the heater/air conditioning system vacuum supply line connector to the T-fitting near the heater core tubes.
  9. Connect the heater hoses to the heater core tubes.
  10. Connect the refrigerant lines to the evaporator.
  11. If equipped with air conditioning, evacuate and charge the air conditioning system refrigerant.
  12. Install the instrument panel by performing the following procedure:
    1. Using an assistant, install the instrument panel to the vehicle.
    2. Install the 4 upper instrument panel-to-dash nuts.
    3. Install the 3 instrument panel-to-door hinge pillar screws.
    4. Install the upper cover to the instrument panel.
    5. Reaching through the glove box opening, connect the following items.
      Two lower passenger-s side air bag module bracket-to-dash panel nuts. Passenger-s side air bag ON/OFF switch wiring harness to the retainer clip on the plenum bracket that supports the heater/air conditioning housing just inboard of the fuse block module. Two instrument panel wiring harness connectors to the passenger air bag ON/OFF switch wiring harness connector. Two halves of the radio antenna coaxial cable connector. Side window demister hose at the heater/air conditioning housing demister/defroster duct (passenger-s side). Instrument panel wiring harness connector to the passenger-s side air bag module wiring harness connector. Instrument panel wiring harness connector to the heater/air conditioning system wiring harness connector. Two halves of the heater/air conditioning system vacuum harness connector.
    6. Install the glove box.
    7. Under the driver-s side of the instrument panel, connect the following items:
      Side window demister hose at the heater/air conditioning housing demister/defroster duct on the driver-s side. Instrument panel wiring harness connector to the 100-way wiring harness connector at the left side of the inner panel.
    8. Install the steering column.
    9. Install the knee blocker to the instrument panel.
  13. Connect and remove the negative battery.
  14. Refill the cooling system.
  15. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Hope helps (remember rated this).
Jun 25, 2010 | 2001 Jeep Grand Cherokee
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Water heater ground
You have clearly lost your ground due to PVC. One solution would be to run copper ground wire from the hot water tank to the metal splice on each end of the PVC. It is not necessary to go all the way back to the breaker box.
Jan 23, 2009 | Water Heaters
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
