Question about RCA RS2656 Shelf System
How do you set the clock on an RCA RS2657 Bookshelf stereo system?
5 Suggested Answers
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
shaggyrat
  • 1224 Answers
SOURCE: Bought a display model RCA RS2657 5-Disc CD Changer Bookshelf Audio System
order from remotes plus or order from rca themselves
if system is aloted a universal remote should be able to control the system with little or no hasle
Posted on May 09, 2008
  • 4 Answers
SOURCE: Panasonic SA-AK27 Bookshelf Stereo - Setting The Clock
Have you put on the eco mode? try this: power on the unit, click on the eco button, until the unit will display "normal"
Posted on Aug 10, 2009
SOURCE: HOw do you set the clock on an RCA RP9328A stereo without remote?
I have this system. According to the manual you have to do the following. 1. Press and hold the TIMER/CLOCK button until CLOCK appears in the display under the time. 2. Press the SET button once and the hour will flash. 3. Use the << or >> buttons to ascend or descend to the correct hour. 4. Press the SET button again and the minutes will flash. 5. Use the << or >> buttons to ascend or descend tot he correct minutes. The time will flash for a few seconds and be set when it stops. I have tried those steps and you may have to do them a few times in order to get the time right. It's a little tricky. I haven't bothered to reset the time as I have other devices that display the time without the back and forth with this device. It's a nice system and the sound is okay for my purposes. Hope this helps.
Posted on Jun 28, 2011
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
Jul 07, 2009 | Panasonic SC-AK27 Shelf System
Mar 17, 2008 | RCA RS2656 Shelf System
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
RCA RS2052 Bookshelf System
Have you tried cleaning the sensor on your stereo, and also the transmitter on the front of your remote? Otherwise check the battery terminals in the remote for corrosion to make sure the batteries havent leaked.
Nov 27, 2007 | Thomson RCA Bookshelf System with 128 MB...
Can you tell me how to change the clock on my RS2652?
press and hold the "CLOCK" button until the time flashes, the using the << & >> buttons, adjust the hour, press "CLOCK" once more to select minutes. again, using << & >> to select time. press "PROG. SET" once. good luck
Nov 20, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
Rca compact stereo rs2657 cd door won't open
Sep 25, 2007 | RCA RS2656 Shelf System
RCA RS2656 Shelf System Logo
227 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
