Question about Brother XR-65t Mechanical Sewing Machine
I lost the little clear plate that covers the bobbin on my Brother XR-65. Where can I easily order a new one? Thank you,
    Genius:
  • 1,788 Answers
Call and order directly from Brother at 1-877-276-8437.
Posted on Oct 10, 2010
NEED MANUAL FOR BROTHER XR 65
try the brother website
sewingpartsonline.com
sew4less.com
sewusa.com
ebay
a1sewingmachines.com
Apr 22, 2012 | Brother Sewing Machines
I can not thread a bobbin to save my life. Help.
first, google your sewing machines name and model number and "manual" or "users guide" and you can find the link to the PDF download. Here is what I found:
1 Raise the needle to its highest position by turning the balance whell toward you (counterclockwise) and raise the presserfoot lever. Slide the button and open cover.
2 insert the bobbin so the thread comes out in a clockwise direction. Use bobbins intended for this machine. !CAUTION! Be sure the bobbin is set so the thread unrols in the correct direction. If the thread unrolls in the wrong direction, it may cause the thread tension to be incorrect or the needle to break.
3 Hold the thread end, push the bobbin down with your finger, and pass the thread securely through the thread cutting groove.
4 Replce the bobbin cover. Place the left tab in place then press lightly on the right side until the cover clicks into place. *insert the cover so that the end of the thread comes out from the back of the cover.
good luck and G.Bless!
Oct 16, 2009 | Brother XR-65t Mechanical Sewing Machine
Bobbin cover plate
click this link directly.http://www.euro-pro.com/europro/categorybrowse.aspx?cat=Sewing(EuroPro) ------------- this is direct link for the service center.you will have to enter the model number and place the order.this will help you.
Sep 16, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Lost the clear cover that snaps over the bobbin
hello it is called the hook cover plate. go to kenmore .com check accessories
Mar 06, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Feb 01, 2009 | Brother CS-8060 Computerized Sewing...
I forgot how to install my bobin
Hold it in your right hand by one of the flat sides. The thread should come off the top of the spool going away from you. Lower it into the bobbin hole and replace toe top cover.
Jan 05, 2009 | Brother XR-65t Mechanical Sewing Machine
Brother xr-65 bobbin problem
insert the bobbin so the thread comes out in the middle a away from you, hold the thread end push the bobbin down with with your finger, and pass the thread securely through the thread cutting groove
Oct 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Bobbin tangles on Brother xr 65
This was happening to me too, I reversed the bobbin feeds and it has not tangled since then. I was orignally feeding the bobbin from the left side and now i feed the thread from the right. It works great this way.
May 19, 2008 | Brother XR-65t Mechanical Sewing Machine
Need to replace a bobbin cover plate
Here in Australia, the dealer would get it in for you. The 'manufacturer' / distributor usually don't get involved with customers! I'd find a dealer near you and ask!
Oct 08, 2007 | Sewing Machines
Brother XR-65t Mechanical Sewing Machine Logo
121 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
