RX-V 563 Sound Set Up
I have set up this amp using the auto set up but now when it is in the dolby digital mode the voices are extremely low. The sound overall is good but you can't hear the voices very well both when watching a tv show or a dvd.
  • dad99 May 27, 2008
    Center channel is working. I will attempt to make some changes and check speaker levels, although I have already tried some changes through the manual set up without success.
    Problem Solver:
  • 15 Answers
Most likely the center channel speaker is not working. Try the setup function again. If the center is not working, it should compensate by using the left/right mains.
Also consider doing a manual setup for the sake of diagnosing the problem. Set all speakers to small, and check levels one speaker at a time.
Posted on May 27, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Uneven sound
With a Dolby 5.1 surround sound system, the level of each speaker is adjustable. Consult your owner's manual. It sounds like the center (voice) channel is set too low, or the left and right channels are set too high.
Feb 13, 2014 | Panasonic SC-PT875 Region Free 1080p DVD...
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Samsung DVD-R155 will not play in Dolby Digital surround sound
You need to buy a digital coax cable Just 1 run out of player and into amp!
Dec 06, 2008 | Samsung DVD-R155
Onkyo receiver TX-DS696
If you get sound on direct mode say from dvd but no sound when you go to dolby make sure you have the right input selected by pressing the digitat input button on the front of the amp,ie if dvd optical out is pluged into amp optical input 1 select this on amp then set audio to prologic2.DVDs through this input will decode to dolby digital/dts.
hope this helps.
CABLE GUY.
Jun 25, 2008 | Audio Players & Recorders
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Out to speakers only in 5CH mode, or front L/R
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
Jan 26, 2008 | Denon AVR-2807 Receiver
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
Yamaha rx-v595a problem with dts signal
the unit must be switched to digital in order for the auto function to work, then it will automatically select dts or dolby digital. youn need to check your digital feed from the dvd player.
Dec 28, 2007 | Yamaha RX-V595A Receiver
228 people viewed this question
 Grubhead
Grubhead
