Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
A small pink stripe down the left side of my HP laptop display screen. What's up??
  • 734 Answers
It probably means that you're very lucky that your screen is failing and probably NOT the Video Card on *********** board. Either borrow a monitor and hook it to your computer (and see if the line appears on the borrowed monitor...if not, you know your monitor is failing) or take your computer to a friend's place and hook it to his/her monitor which will produce the same troubleshooting answer with the reversed conponents, if the line appears on his otherwise normal LCD, your video card is the problem.
Best Regards,
TheSelkie
Posted on Oct 03, 2010
Testimonial: "Thank you very much! I will hook up and let you know."
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Need a hp part number for a lcd display for a HP Pavilion dm4t-1200 laptop.
I would like you to try using HP's Part Surfer.
1) Put your Product Number, or Serial Number in the Quick Search box,
(P/N = Product Number.
S/N = Serial Number.
{DO NOT give out the serial number on a public forum such as this. Only on the HP website}
2) Then click the blue down arrow on the right side of the - Select a country or region - box, and click on your country.
3) Finally go back to the Quick Search box, and click on the side arrow to the right.
Post back in a Comment as to your findings.
We'll go from there.
On the back of the LCD screen is the HP part number.
http://www.screentekinc.com/HP_Pavilion_DM4T--14-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
{Scroll the page down, and see if any of the 36 part numbers may be a match}
Display LCD screen replacement instructions,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm4-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-hp-pavilion-dm4-laptop/
Awaiting additional questions. Please post in a Comment.
Regards,
joecoolvette
[ P.S.
You can disconnect the LCD display, and use an external VGA monitor, while you wait for the replacement LCD screen.
1) Laptop off, VGA monitor off.
2) Connect the VGA monitor to the Left side of the laptop.
( External monitor port. The VGA connector resembles this one,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
3) Turn the VGA monitor on. Wait for it to 'warm up'.
Turn the laptop on.
If the display does not automatically go to the external monitor;
Press, and hold down on the Fn key.
Tap the F4 key.
(The VGA monitor can be a CRT monitor, {Looks like a small TV}, or a flat LCD screen monitor that has a VGA connector, and a VGA cable ]
Sep 04, 2011 | Computers & Internet
My compaq presario cq62-238dx felloff my hands, no scratches or damages are visible, when I first turned it on it worked as if nothing would have happenned, but later on the screen turned pink, the next...
I suggest you start diagnosing by using an external monitor, if available.
A VGA monitor.
(It can be a VGA monitor that looks like a small TV, {CRT}, or an LCD flat screen that has a VGA cable attached.
More information on VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Laptop off, and VGA monitor off, connect the VGA cable of the monitor to the Left side of the laptop.
(Rear top port)
Turn the monitor on, and then the laptop.
Do you see a display on the external monitor? (VGA monitor)
No?
Press, and hold down on the Fn key (Function Key), and tap once on the F4 key.
A) If BOTH the external monitor screen, and the laptop screen have the same pinkish display, the problem is the graphics chip. (More on graphics chip in a moment)
B) If just the laptop screen is pinkish, and the external monitor graphics are okay, the problem is inside the laptop display.
1) Could be a loose connection of the Display Panel Cable.
{The Display Panel Cable attaches to the motherboard, and the LCD screen in the laptop display}
2) Could be a bad Display Panel Cable.
Possible damage to the Display Panel Cable is the the laptop display was open.
Look for signs of damage to the sheath of the Display Panel cable.
However the damage may not be apparent. The Display Panel Cable could have been stretched.
(Laptop display open when dropped)
The tiny wires inside the Display Panel Cable could have become damaged.
Testing requires that the Display Panel Cable be removed.
A multimeter is used to check continuity of each wire.
{Multimeter function knob is set to Ohms. 1K or 10K if these settings are available.
The Positive probe lead (Red) is touched to a wire at one end of the Display Panel Cable.
The Negative probe lead (Black) is touched to the other end of the wire.
Analog multimeter needle swings up, you have continuity. Don't worry about the Ohm reading at this point. As long as the needle moves.
No movement? Have a helper gently move the Display Panel Cable around.
See if there is continuity shown, or is intermittently shown.
Indicates a break in the wire.
Solution is to replace the Display Panel Cable.
Same with a digital multimeter. No reading, or intermittent reading indicates a broken wire.
Display Cable Kit - HP Part Number 595196-001
I have seen several listings on the internet.
3) Could be a bad LCD screen.
Check the connections.
Check the display panel cable
If this checks out okay suspect the LCD screen.
Compaq Presario CQ62-238dx Notebook PC - Service Manual,
(Free from HP Support),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4252487&
Left-click on -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC - Maintenance and Service Guide
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
In the Bookmarks menu on the left, click on the + sign to the left of Removal and replacement procedures.
Now click on the + sign to the left of Preliminary replacement requirements, then go on to Component replacement procedures
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 19, 2011 | Compaq Presario CQ62238DX Laptop
I have got a problem with my Acer Aspire 9500 notebook.Few months ago on LCD screen (17``) show up green stripe (vertical on the middle of the screen).Two days ago another one shows up (pink, also vertical...
That sounds like you are developing a faulty screen. Spares are plentyfull on ebay.com and not that expensive.
It may be a poor connection on the rear of the screen but not very likely. If you plug your laptop into and external display, to prove the VGA processor is OK first before purchasing a new screen. Replacing the screen can be done at home if you are mechanically minded and methodical. Ensure you adhere to anti static precautions!
Hope that helps.
Feb 03, 2011 | Computers & Internet
Hello..i have laptop hp dv2750 model..display is not working properly but it has power..the screen appears sometimes stripe green of stripe pink..now i cant open it anymore..what is the problem with my...
On your model the Plugin on the mainboard for the LCD is on the left next to the power button under the power panel. You can remove the power panel by pulling the battery out by removing the screws in the battery compartment area. It may take some effort but the Power panel can be taken up and you can make sure that the LCD cable is plugged in tight.
This can also happen because of a bad LCD, cable, or video card. See my post here:
http://www.fixya.com/support/t2998701-no_display
It explains the basics of why it happens and what you can do about it.
Hope this helps and if it does please rate it. Thanks...
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
1/2 screen Blk w 2" Stripes & UPSIDE DOWN/drop Dell Inspiron2200
well im not a great tech but i can give you one solution, you can try to connect it to ANY monitor from the VGA port of your laptop, just find a PC monitor to do this with. to "flip" the screen to different angles you will have to be logged on.
Hope this helps, i you have any further questions just ask
Apr 10, 2009 | Dell Inspiron 2200 Notebook
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
3 Stripes on 1 side of the screen
Ask these guys http://lcdrepair.net
Sep 30, 2007 | HP Pavilion zd7020US Notebook
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
419 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
