Question about Refrigerators
Has power at the outlet; no interior lights; checked/replaced bulb light won't come on; no compressor coming on though door was left open to check light. Just vacuumed underneath with shop vac. before problem. Don't think I hit anything but there is a clear plastic fitting with a wiring harness coming out of it underneath near the middle left side front with the kick plate off.
  • 857 Answers
While cleaning there is a possibility that there is a disconnection in one or more cables due to vaccum suction which has resulted in interruption n power supply due to which the lights are not coming up and the compressor is not turning on, i will suggest you to relook overall wiring definatley the problem is not with the compressor, If you are not an expert To get the same done counsult a local repair guy.
Posted on Oct 03, 2010
2009 Ford Escape interior lighting don't work when opening the doors
Check the switch that turns interior lighting off.
Sep 01, 2017 | Ford Cars & Trucks
All interior lights and trunk light will not come on.
There is a fuse for these. Fuse good and has power to it. Look at replacing the light/dimmer switch. If the fuse is good, you need to check for power at the switch plug. Could be a bad wire.. Power or ground.
Sep 03, 2016 | 2004 Volvo S40
I have a 2005 jetta and the dome lights don't come on when any doors open
I assume if the interior light didn't work at all you would have said so.
When the interior light works but the courtesy light function doesn't the culprit is usually the door switch or switches.
Sometimes located at or near the striker plate the pillar at the door hinge end is a more common location for the switch to be (usually) secured with a single screw, though sometimes a rubber cover must be removed to access the screw.
The function of the switch is to ground a single wire when the door is opened. Sometimes a switch must be replaced and sometimes a thorough clean and a spot of lubrication will put matters right.
Feb 09, 2015 | Cars & Trucks
Interior lights won t turn on
It can be one of two problems. One: pending on what kind of car you have. ..there is a switch near the steering column that turns left or right...adjusting your dash lights and or turning on/you interior lights.#2...check the interior fuse bus panel/box
May 22, 2014 | 2005 Jaguar S-Type
Trunk cargo light not working after LED installed....
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Visual Inspection Chart Mechanical Electrical
  • Courtesy lamps
  • Map lamps
  • Luggage compartment lamp
  • Vanity lamps
  • Glove compartment lamp
  • Smart junction box (SJB) fuse 3 (15A)
  • Circuitry
  • Courtesy lamps
  • Map lamps
  • Vanity lamps
  • SJB
Check fuse # 3 SJB
Jul 07, 2017 | 2010 Ford Fusion 2.5
The lights in the back of the car do not work. They are the ones right above the door. The lights up front work though which are attached to the mirror.
INTERIOR "COURTESY" LIGHTS OFTEN ARE OF A PUSH IN TO TURN ON...PUSH AGAIN TO TURN OFF TYPE. WHEN DOOR IS OPENED....PUSH ON LENS OF LIGHT ...BET YOU THEY COME ON..IF NOR..CHECK BULB, OR FOR POWER AT CONNECTIONS, NEXT CHECK ALL FUSE PANELS...COULD BE A SEPARATE FUSE
Aug 10, 2012 | 2001 Chevrolet Impala
Interior light won't come on when I open the front doors
If you have tried to adjust your interior lights with your dash light adjuster, and it didn't work, I would say you either have a bulb out, or a blown fuse. Hope it's something simple for you. GOOD LUCK
Jul 02, 2012 | 1994 Oldsmobile Cutlass Ciera
Interior light will not come on when doors are opened
Maybe check to see if your button next to your headlights switched is pushed in or out?
Mar 08, 2010 | 2004 Chevrolet Tahoe
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Oct 13, 2008 | AEG Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
