Question about Canon L120 Fax Laser Printer
Comm error 0091
Fax is conneted to nortel 11c PABX via analogue card. Corporate VoIP network connected to pabx via cisco 2600 router. I cannot transmit fax messages via the VoIP network, but can receive over the VoIP ok. Messages transmit ok through PTT lines ok
  • Anonymous Aug 18, 2008
    once i want to send fax it gives me error 0091 what could be the problem?
  • xkamerx Dec 24, 2008
    i am havin the same problem with cisco ata 180
CompuGuy44
  • 432 Answers
SOURCE: Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Posted on Jun 25, 2007
SOURCE: CANT SEND FAX THRU VOIP LINE
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
Posted on Jan 30, 2008
SOURCE: Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Posted on Sep 20, 2008
old marine
  • 2039 Answers
SOURCE: I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Posted on Oct 16, 2008
MUKHTAR
  • 2022 Answers
SOURCE: My Canon MFP4150 cannot send international faxes.
make sure the the phone line which you using having ISD calling facility in dialing 1 st you try that no by dialing with the normal phone.
Posted on Jan 20, 2010
Do i need a spechel line for a fax ore it can be a reguler phone line ?
A regular Analogue phone line.
Analogue ! Not a PABX phone line which is most likely Digital .
IF using ADSL you need an ADSL filter and need to put FAX line into Phone part of Filter.
Oct 11, 2015 | Office Equipment & Supplies
Uniden troubleshooting
was the old phone connected to a Private Automatic Branch Exchange P.A.B.X like for example a comander system if so the new phone would have to be a PABX type phone extention type. I suspect the Uniden phone is not compatible with the PABX extension socket.
http://www.excitingip.net/291/ata-analog-telephony-adapter/
http://www.kosmaz.com/ata.htm
http://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-186-analog-telephone-adaptor/product_data_sheet09186a008007cd72.html
I do not know what phone system you are using you might want to find out the model number of your PBX device and research if it uses VOIP = I can only guess that this is the situation
Sep 01, 2014 | Radio Communications
Error 20 01
Error 20 01 indicates that there is a communication error on the telephone line connected to your MFC. Either the line is noisy, not connected or perhaps connected via a PABX or a VOIP modem or similar? so it will not work. Try plugging a standard telephone into the socket and see if that works. At the very least you may well be able to "hear" the fault. At the very least, the fault is external to your MFC and not within the machine itself
Nov 06, 2013 | Brother MFC-8910DW Laser Multifunction...
How i can install external page port of a pabx Norstar with output of 600ohms to the input Radio shack 250 Watts PA.
Connect Nortel PABX external page port output to the amp input.
Either by phone plug or RCA connector, any of the two will work.
Apr 19, 2011 | Radio Shack 250 Watt PA Amplifier...
I need to delete 9 from the dialing string on an omni 3200
From main screen: Press first purple key on the left until you see Other Setup. Select Other setup. Input password (1, alpha, alpha, 66831 is most likely). Scroll down to Comm, select Comm.
From Edit CPT #1/2 press Slct. Press next until PABX Code appears. Press Edit. When you see New: press Enter. The field should now be blank. Press exit, then OK to save changes
From Edit CPT #1/2 press Next, then Select. Press next until PABX appears and repeat as above. When complete, press exit, then Clear until the default screen reappears.
Jul 30, 2009 | VeriFone Computers & Internet
3055 trying to fax getting COMM. Error?
It's probably your phone-line that causes the problem. The fax-module in your machine needs a 100% analog phone line. HP garantees nothing when using IP/ISDN/PABX-lines. Try lowering the baud rate, turn off JBIG compression and error correction mode, but if the problem remains, you better replace your phoneline.
Jul 23, 2009 | HP LaserJet 3055 All-In-One Printer
Interconecting 2 Panasonic KX-TDA 200 & KX-TDA600
You are asking for some very advanced setup features, as far as connecting them you need the IPGateway cards. They are cat5 cards that will do the trick. However programming the setup to do what you want will be VERY time consuming and not to easy to walk someone through. On-site tech is highly recommended for that much programming and work.
Feb 24, 2009 | Panasonic KX-TDA0410 (KXTDA0410) Network...
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Faxes not going through
Kindly update the model number. and region. Where the problem is.
Are you using any PABX or VOIP line etc.
Sep 26, 2008 | Samsung Office Equipment & Supplies
There is a big trouble
all faxes use automatic fallback sytem for dropping the speed as well as the machines communicate on the highest common speed therefor you don't need to set the speed. Apart from the situation if your phone line is disturbed and not receiving faxes and giving communication errors.... happy faxing omnipresent
Nov 08, 2006 | Xerox FaxCentre F110 Plain Paper Laser
Canon L120 Fax Laser Printer Logo
389 people viewed this question
old marine
old marine
