Question about Kenmore 22313 Bagged Canister Vacuum
A piece of string / cord has wrapped around my Kenmore spinning brush end on the 12 Amp Power - Mate. How is the best way to get the cord off?
  • 694 Answers
Cut the string with a knife or scissors and pull it off. You can turn the brush manually to ensure you get it all.
Posted on Oct 04, 2010
How do I fix my vacuum the brush will not spin
Lubricate each end of the roller brush with motor oil. Bearings inside the roller brush need lubrication for the brush to turn easily. Remove any pieces of thread that have wrapped around the roller brush. If it does not spin after doing the above steps, then either the belt is slipping or the bearings are severely damaged in the roller brush. Then you need either a smaller belt or a new roller brush.
Apr 26, 2015 | Dirt Devil UD40270RM Quick Power Compact...
Www vax co uk support
Check that there are no long hairs, string or carpet twine wrapped around the outer ends of the brush. Also remove the brush from the housing and make sure the bearrings on the outer ends of the brush is not siezed.
Aug 26, 2014 | Vacuums
The brush on my Pet Power Mate attachment for my Kenmore isn't spinning. can it be fixed?
In my case the brush was seized on the axle. A wad of pet hair had wrapped one end and melted the plastic roller a little, binding it to the axle. Take the powerhead apart; Pull the white ends off the axle; Push the axle out; ream out the holes in the roller ends with the proper sized drill (#12 or 3/16", I think...close is good enough); Clean any debris out of the roller and steel wool the axle if necessary; Light oil lube job; and reassemble.
Feb 02, 2012 | Kenmore Vacuums
The brush wont rotate on my windtunnel vac but it still has suction. Could this be a broken belt?
Yep - that's usually the culprit if the brush stops turning. However, pull off the skid plate (bottom panel) and make sure you haven't picked up any string or some other obstruction that's wrapped itself around the brush & stopped it from turning. Things like hair/string don't always end up in the bag/bin sometimes if they're long enough they just wrap themselves around the brush.
Jul 13, 2011 | Hoover Vacuums
The brush is not spinning on its owm. Not picking up any thing
Unplug the machine and then inspect the brush. You might find thread, string, or wire wrapped around it preventing it from spinning. Also check the edges of the brush roller and make sure there are no fibers, etc. wrapped into the wheel well. These are the usual causes of the brush failing to spin. I hope it solves your problem. If it does, please rate my solution. Good luck
Dec 22, 2010 | LG Kompressor Upright Vertical Cyclone...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
The roller that spins with little brushes stopped suddenly and no longer spins. I pressed the red little knob at the end of the roller but it doesn't fix the problem.
open up the roller area check to see if somthing got picked up and jammed into the rollers so that it can't work, a rock or a screw or you might even have a large amount of string or fibers wrapped around the shaft or brush keeping it from rolling
Feb 19, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Agitator unit on Kenmore Progressive 116.25915503 won't spin. I have cleaned out all hair and string wrapped around it. Belt is good. It seems to spin on one side but stuck on the other. Could string be...
Pry the end caps off the brush bar, you will find hair and string wrapped up tight in the end. the bearing may also be shot, you can try and oil it up a bit to keep it spinning. <!-- from fixya rte -->
Oct 21, 2009 | Kenmore Vacuums
My Oreck has in the last 2 weeks become very hard to push on carpet , ok on bare floors. Thanks
Look at 3 things:
(1) is there something wrapped around the rear
wheels or axles?
(2) Is there something wrapped around the small, front wheels or axles. (not likely this is the culprit.)
(3) Is your brushroll still turning. (This requires looking underneath while unit is on, have someone else nearby to pull the cord from wall, turn on & off quickly and make sure brush roll spins.
If it is rear wheels, you can pop them out if necessary to clean the debris, they may be hard to press back in. Similar for the small front wheels, don't loose the axles. If brush roll is issue, check belt, insure that brush roll will spin freely and does not have debris wrapped around it.
Aug 12, 2009 | Oreck XL2000 Bagged Upright Vacuum
How do I take the brush out?
Most of these progressive drives have a bottom plate that you can take off, then you can get to the brush roll asm. There will be several screws.
Feb 17, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 22313 Bagged Canister Vacuum Logo
191 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
