Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Prints on only 1/2 of sheet of paper
When I try to print anything from the monitor screen, it prints only on 1/2 the page--the right half. It will print the full header which I have not selected to print but everything else is on the right 1/2 of the page.
  • 75 Answers
Let's verify the main source of the problem:
Are you possibly printing web pages? Some are not very printer friendly, and could fit the description you give.
If you can print successfully from another application (notepad, MS Word, etc.), your printer is working and the issue is software related (setup, etc.), and not the device. Check your page setup to see if you have the correct page size, orientation and offsets set correctly.
If all apps fail, check your printer's User Guide for more information.
Posted on Jun 09, 2008
Prints clean sheet - not printing anything on the paper
mine did that too, no text on page, we had to change the defeat setting from the router.
Mar 20, 2014 | HP LaserJet Pro P1102W Printer
Prints on partial page of an 81/2 x 11 photo paper. Prints OK letters fm word.
Instead of using the Letter or factory 8 1/2 x 11 page set up, create a custom page size for 8 1/2x11 and use that in your app for the page set up. Double check your page orientation and the size of the photo you are printing. It sounds like it may be trying to tile the photo because it's too large for the page size.
Sep 14, 2017 | HP Photosmart C6280 Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
When printing on the 4250, the margins are moved to the right of the paper cutting off the text. This is an XP computer and the PCL and PS drivers have been tested...
I would check to make sure that the paper trays are set properly and paper size is being detected properly. Print out the configuration page and see if that prints correctly. If it shows the same shift in image, check the paper sizes that the configuration sheet shows to make sure it is reading the trays properly. If the trays are reading properly and test print prints properly, then it is either your driver or the software you are printing from that has a problem.
To print the configuration sheet, press the down arrow button until the screen reads "information", press checkmark and then use the down arrow until "configuration page" is highlighted and then press the checkmark again. After a few seconds your page will print.
Apr 27, 2011 | Office Equipment & Supplies
Printer prints out blank pages
Follow these steps:
1. Load a few sheets of plain paper in the sheet feeder.
Turn off your printer.
Hold down the paper button as you press the power button to turn the printer back on. Hold down both buttons until the power light begins to flash, then release the buttons.
The printer prints its test page, which includes a nozzle check. Does the paper print out without any gaps or with gaps? If there are do this:
2. Load a few sheets of plain paper in the sheet feeder.
Make sure the printer is on and the ink light is off.
Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Head Cleaning.
Follow the on-screen instructions to start the cleaning cycle, which lasts about 1 minute. The power light flashes throughout the cleaning cycle and stays on green when the cycle is finished.
Never turn off the printer during a cleaning cycle or you may damage it.
When the power light stops flashing and remains on, you can check to see if the nozzles are clean. Click Print Nozzle Check Pattern and click Print. Check the printed nozzle check pattern to see if there are gaps in the lines.
If there are no gaps, click Finish.
If there are gaps or the pattern is faint, click Clean to clean the print head again.
You may need to clean the print head up to 4 times. You can also turn off the printer and wait at least 6 hours. Then try printing again.
If this doesn't work then double check that you have the toner cartridges in correctly. If you do then your print head is broken and/or burned out and it's best to just replace the printer. Fixing it would cost more than the printer itself
Jan 17, 2011 | Brother MFC 420CN All-In-One InkJet...
When I send my job to the printer. The printer will print but only on 1/2 of the page. it looks like the printer think i want two sheets on one page
Is the whole page you want printed on half the page is just half the data printed? If the whole page is printed on half the paper then the problem is software. If the page only prints the left side or the right side blank on the other side then the problem is most likely the fuser assembly. Can you take a picture of the page and email it to us, we will email you back with what needs to be done next.
Apr 30, 2010 | HP LaserJet 2300 Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stops printing a full page picture half-way through and prints the rest on the next page in some random place. I have also had some problems printing text in the same way. The picture I am trying to print...
I noticed that when I restart Windows, I can print one sheet fine, the second sheet prints only half. Restart again, and I can print one more sheet.
My local Canon helpdesk proves as unhelpful as all helpdesks these days.
Dec 07, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
99 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
