Question about Dell Dimension XPS PC Desktop
DELL XP CAN NO LONGER LOG ON TO COMPUTER, STAYS ON WINDOWS BANNER. I GO IN TO SET UP AND IT READS: ERROR CODE 0F00:0244 READ TEST UNCORRECTABLE DATA ERROR. HARD DRIVE OR MEDIA WRITE PROTECTED.
  • 68 Answers
Turn on your system when you see the dell logo, tap on f12, there is an option there to click on IDE DIAGNOSTICS, or utility partition, using your arrow keys choose any of these and run the test, it will tell you if your hd is bad, if not you might be able to do checkdisk by using the xp disk and go to the recovery console.
Posted on Oct 31, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey mguerrero,
Based on the error message provided, it appears that the hard drive on your computer may have developed what is referred to as a "bad sector." When this occurs, any information that is stored in that portion of the hard drive may become corrupted, damaged or lost. In this case, the bad sector may have directly affected a Windows start-up file, preventing you from being able to complete the loading process.
Bad sectors can develop for a number of reasons including manufacturer defects in the hard drive, as well as being a part of standard wear-and-tear.
The unfortunate part of this type of issue is that bad sectors tend to "spread" once they have surfaced. While preventative measures can be taken to isolate and mark bad sectors as unusable, there is no guarantee that the hard drive will not suffer another similar failure down the road.
For the average computer user it may be suggested to seek data back-up of any important information and to replace the hard drive, but more advanced users can always attempt to resolve this type of problem on their own by using any number of diagnostic/repair tools developed by either Microsoft or the hard drive manufacturer itself.
If you are unsure of how to proceed or would like further assistance, you may always speak with a Geek Squad® agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 27, 2008
    Problem Solver:
  • 13 Answers
This error code refers to "bad Sectors "on your harddrive ....and they cannot be accessed ......meaning your drive is probably toast or close to it .....there are HD diagnostics test you can download and run from the HD manufactuer....
Blue Screen doesn't load Operating System. I beleive there is a software conflict when my daughter downloaded an application she needed for university
If you are getting 'Uncorrectable data Error or Media' for your internal hard drive then it is likely that you have a disk problem rather than a software conflict caused by anything your daughter downloaded.
If the Dell diagnostics provide no solution, then you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) from http://www.hirensbootcd.org/ then would need to be burnt on to a blank CD then the laptop booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need your Windows install or recovery CD media.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
IDE disk read test block failure
try to run with chkdsk command and if it is fail kindly replace the disk.
Nov 14, 2011 | Dell Dimension 4600 PC Desktop
OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Nov 13, 2010 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Dell won't boot up. The following problems isolated by F12: 3600:0123 Battery test failed 0F00:075D IDE device failed: the self test failed to read ... 0F00:0244 Block 1905 74359: uncorrectable data error...
sounds like a complete motherboard failure with a lot of other problems.
if you remove the HDD ( turn the machine over. 2 screws on the right.slide drive out ) and mount it in an external caddy you should be able to use another machine to access the drive and probably get most data off it.
Aug 02, 2010 | Dell Inspiron 6400 Notebook
I WENT FOR EXTENDED TESTING FOR MY DELL VOSTRO SYSTEM.. AND RECEIVEED ERROR CODE: 0F00:0244 MSG:DISK_0 BLOCK 34410367 CANT READ, REPLACE DISK OR REMOVE WHITE PROTECTION.. WHAT DOES THIS MEAN??
Uncorrectable data error code or media is write protected which mean the test found a big problem have a computer repair shop look at it.
Jun 16, 2010 | Dell Vostro A860 Notebook
Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
May 31, 2009 | Dell Inspiron 6000 Notebook
Error code 0244
Hi there.
Error Code 0F00:0244
"Msg Block 5*****4: Uncorrectable data error code or media is write protected"
Sorry to say the hard drive has failed or is corrupt with bad sectors, with these Dell drives there is no way of fixing them.
There maybe a possibility that you can recover your data if it still spins up and you add it to another computer as a slave device.
Good luck and thanks for using FixYa!!
May 20, 2009 | Dell Computers & Internet
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Dell Dimension XPS PC Desktop Logo
168 people viewed this question
Alun Cox
