Question about Skil Saws
I have a 10" motorized band saw by skil.the model number is 1304.the blade keeps slipping off the pulleys.
rowdy45176
  • 2176 Answers
SOURCE: Proper Band Saw Blade
I was just on Sears website and if you go to the bottom of page you can link over to Sears Parts Direct and type in your model number and you should be able to get it online. Good luck
Posted on Dec 21, 2008
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
Editor925
  • 285 Answers
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Posted on Apr 18, 2009
How do you keep the blade on a 386 band saw from coming off all the tim when puttin on a new one
There are lots of informative blogs on bandsawblog.com . Search for Band saw blade tracking , How to Change band saw blade, Blade tension .
Aug 27, 2014 | Skil 3386-02 9-in Band Saw with
Where can I get the parts for the upper and lower blade guides for my skil 10" bandsaw model 3104
Try to contact Skil, if they can't provide you. Check with Carter Products ; they supply bandsaw guides for all types of saws.
Jun 12, 2014 | Skil Saws
Where can I get the upper and lower blade guide parts for my skil 10" bandsaw model 3104
Inquire with Skil tools or you can also check Carter's band saw guide kit.
I have a fairly new Stil 3385-01I have finally adjusted my saw so that the blade does not come off. But its now stalling as I cut an oak piece even as I cut with the grain. I have adjusted the tension...
How thick is the oak, and what is the amperage of the motor. This may be a trim saw. Make sure your pulleys don't have drag. Blade tracking is a common problem with ban saws. Use least amount of tension necessary to keep from slipping or jumping off.
Dec 18, 2010 | Skil 338501 9inch Band Saw
Turn saw on, Curcuit pops immediatly
The motor is bad. It is drawing too many amps.
Jan 28, 2010 | Skil 3385-01-RT Factory-Reconditioned 9"...
Can I download a manual for a Skil 10 inch band saw
You can find most product/tool manuals at the manufactures website. I have provided a link to the manual for current model of bench-top Band Saw by Skil.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000001/r01047v-1.pdf
If this is not your model, then follow the link below, where you can locate your Band Saw by model number.
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
Hope this helps...
Aug 08, 2009 | Skil Saws
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
Dec 17, 2008 | Saws
Saws Logo
189 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
