Question about Brother MFC-8460N All-In-One Printer
Need to add mfc8460N to computer, don't have disk
  • 24 Answers
What is the windows OS of the computer? you can try this link
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8460n_all
Posted on Oct 03, 2010
My HDD HXD 1TB light but don t work
I'm assuming you have a 1TB external hard drive ... that you can connect to your Mac or a PC, e.g via the USB (or Firewire) port.
If the disk drive is formatted for a Mac, the disk (files, format) may not be compatible on a Windows computer. The reverse is not usually a problem.
If you plug it into the Windows computer, and the disk content doesn't show up (quickly), then the disk/file system has been corrupted. It's not likely the disk that is the problem. It's the contents that's all "confused".
If you need to use the external disk drive on both the Mac and PC, try formatting it on Windows (first). Then add contents to it, and it should work for both the PC and the Mac
Feb 19, 2014 | Computers & Internet
I want to know what ram i need for my toshiba tecra A 3 laptop
you will need to add DDR ram first of all clean up your software go to you startup menu and turn of the application that you don,t need to start up when you turn on the computer run disk frac
May 13, 2012 | Toshiba Tecra S1 Laptop Notebook
Format harddrive
What OS are you using?
In Windows, go to the disk management utility and see if the disk is listed. (In Win 7, this is Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions.) For XP and Vista, the directions are similar but do differ a bit. Look at the bottom of the window, to see the list of disks. (Disk 0 is your main hard disk; do not reformat this by accident.)
Assuming the disc is correctly connected to the enclosure and is seen by the computer, you should see it listed as a removable drive. Note: you may need to change the USB port. The MX100 is an enclosure for 3.5" hard disks and needs the AC cord plugged in as well.
You may want to connect and turn on the enclosure when the computer is off, then turn it on. Then turn on the computer. This will hopefully allow the USB drivers to note the new device.
For the Mac OS, look for the Disk Utility.
If you still don't see the drive, check that the cover (and plugs) are completely seated. (Turn off the enclosure first.) Try the hard disk in another enclosure or a USB/SATA hard drive adapter. (If you have a desktop with a free SATA data port and power connector, try connecting the disk directly to the computer. (You need to determine if the enclosure is faulty or the disk itself is bad.)
I hope this helps. Please add a comment with your OS and if you see the disk in the disk management utility, if you need additional assistance.
(This enclosure will work with older versions of Windows, back to Win98Se. However, I don't believe all of those versions came with disc formatting utilities. In that case, you would need a third-party partitioning software (Partition Magic, Paragon Partition Manager). If this disk was in another computer and you want to save the data, try copying the data before reformatting. This may be easier to do with the USB/SATA adapter or the direct connection to the motherboard of a desktop.)
Apr 17, 2012 | Antec MX100 Aluminum Hard Drive Enc e
Need to know had to add printer to computer I do not no the installation disk
Go to Canon's download site on the internet - enter your model and you will be able to download the driver program .If you have Widows7 your computer will find the correct driver for you .
Feb 08, 2012 | Cannon Office Equipment & Supplies
My computer doesn't read dvd & cd s . I neek a driver
You don't need a driver, all the necessary drivers are pre-installed at the windows. The most common error at these cases is a hardware error (scratched disk or defective cd/dvd rom)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 17, 2011 | Computers & Internet
In my computer it said check cable onnectio no bootable inter boot disk ad press any key what i have to do
First of all make sure that there are no USB Sticks or hard disks at the USB ports and in case of a dvd drive existing remove any disk. Reboot your system and check the results.
Thanks and regards
Stelios
May 01, 2011 | Acer Aspire One PC Notebook
My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
Feb 12, 2010 | Brother MFC-8460N All-In-One Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled...
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
My mfc8460n brother keeps gets jam steadily now when I'm copying,
you need to reset the life of the drum. Instruction is included when you purchase a replacement drum
Jun 22, 2009 | Brother MFC-8460N All-In-One Printer
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Brother MFC-8460N All-In-One Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
