Question about Acer Computers & Internet
I have a blue screen whish is a hardware or softwareproblem
    Problem Solver:
  • 7 Answers
It could be software only if you recently done any updates. As you boot up to the computer hit F8 a couple of times and it will take you to prompt pick last known good configuration and that should work. If not go into safe mode and remove all items starting up automatically. if it boots then its software if not it is hardware
Posted on May 27, 2008
Blue screen compaq presario windows xp sp2 cq40
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:
Startup using Last Known Good Configuration to undo recent registry and driver changes.
Use System Restore to undo recent system changes.
Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Oct 10, 2013 | Compaq Presario Notebook
Blue screen
If this didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 30, 2013 | Microsoft Windows Vista Ultimate Edition
Over heats blue screen
Follow these suggestions to solve your problem
- Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
- Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Sep 17, 2013 | Facebook Social Network
Blue screen death
Sep 07, 2013 | Advent Computers & Internet
Blue screen death
you don't write any details.BSOD can be two things hardware or softwareproblem.sometimes microsoft update.try to think back to then it begun,did you install any new software,or hardware.
Jun 18, 2013 | Acer Veriton Computers & Internet
Acer computer keeps crashing
Best thing to try before anything is to run your computer in safe mode.
Make sure the computer is off and not in sleep or in hibernate.
Power the computer on and click the F8 key till you see below image.
Image is from a Windows 7 - Most versions of windows will be the same Or similar. Screen defaults to 640 X 480 in safe-mode!
Choose safe mode with networking. If while running your computer in safe mode and it never blue screens - Then chances are, you have a software, driver or virus issue - Most cases. If your computer continues to crash in safe mode. Your system most likely has a hardware issue. Common: Computer Memory and/or hard drive.
Jun 14, 2013 | Computers & Internet
How to get passed the blue screen and do a factory reset?
RESTAART YOUR COMPUTER.AND GO INTO SAFE MODE REPAIR IT FROM THERE.
BSOD MEANS HARDWARE OR SOFTWAREPROBLEM.
Jun 04, 2013 | Dell Dimension E310 PC Desktop
Hi, During startup, I inserted a USB memory stick and now my screen is all messed up. It is green during startup instead of blue, and in general there are too many green pixels. (and purple pixels too) I...
remove the memory stick then try to boot up again, if still the same try to boot up under advance boot options, pressing "F8" repeatedly on the way up of boot up (from off to on) go to safe mode then try a system restore, see if that helps
Mar 23, 2011 | Medion Computers & Internet
Blue screen physical memory dump?
This is called the Blue Screen of Death or BSoD, this usually happen if u plug in or insert any new hardware. If u have recently added any new hardware, try it out, after plugging off the newly inserted hardware.
Jul 28, 2010 | Microsoft Windows XP Professional With...
Screen stays blue after programs load
if the screen showing blank blue screen or any other colours change the smps and try it once or else if it is showing blue hardware or software error screen remove the last installed/added software/hardware
Dec 22, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
