Question about Whirlpool Duet GHW9150P Front Load Washer
I keep getting F-21 code on my whirlpool duet washer
  • Whirlpool Master
  • 2,605 Answers
Hello, Welcome to FixYa. The "F21" on your model of washer indicates the machine has detected a fault or obstruction in the drain process. Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet. Here`s how to check it and clean it... Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation. If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way. Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose. **Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first** 1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws. 2) You will immediately see the drain pump in front of you with a large removable filter. 3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter. 4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now. ( If the problem still exist`s the "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ). 5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks ! Now You should be good to go. Re-attach the lower panel and you`re back in business. **NOTE: if this still fails to remedy the F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc. **This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.** If you'd like the benefit of this solution with pictures, visit my profile page and look for similar "F21" or "F02" postings they are one and the same just different eras. Let me know how it goes and if you require further assistance. Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today. Good luck. Regards, Macmarkus :)
Posted on Oct 03, 2010
  • twinoaks007 Nov 26, 2010
    I found it a lot less messy by lifting the rubber mount in front and pulling it slightly forward over the front holding tab of the filter/pump assembly, Then pull the two rear mounts up in front and just pull the assembly slightly forward then lift out of the slotted hole for the rear mounts. This will allow the assembly to come forward just enough to hang out over the edge of the washer housing and drain into a bucket or pot when unscrewing the filter cap. This is a lot easier than it sounds and only takes a second. Other than that the advice from Macmarkus is right on track. Thanks!
My washer whirlpool duet steam has a code of F 21 what does that mean
The Whirlpool washer error code F21 means the washing machine has a "water draining issue", meaning the drain pump itself, or the drain hose is clogged and the washer is having problems draining the water out
Mar 30, 2018 | Whirlpool Washing Machines
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
The washer I have is a whirlpool, duet sport washer and for some reason it keeps stopping at F-21. That is whgat is flashing across the display window and it woon't go any futher than that at all. Any...
you have to remove the bottom lower panel(unplug washer first), get some towels,unscrew the pump screen at the bottom right(may need to use pliers to unscrew), clean screen and put it back. WITH DRY HANDS!!! plug cord and test washer. if good replace lower panel. F21 is a Drain took too long fault.
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f 21 on whirlpool duet front load washer
cannot open door on washer it is locked and chothes are inside
Jan 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duetsport front load washer
Check the following link:
http://fixitnow.com/wp/2008/09/27/whirlpool-duet-washer-with-f-21-fault-code/
Nov 08, 2008 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
254 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
