Question about Kenwood VR-605 Receiver
After my receiver warms up if I change functions it loses all sound output until it cools down again. This can take hours. Why does it do this?
  • balcomtl Oct 04, 2010
    When you say that the panel is bad are you referring to the display panel in front which indicates the function and all other things? The reason I ask is it shows all of the other details and to me it doesnt seem logical that the sound would travel through a display panel.
  • 2,069 Answers
There are components that need replacement inside, when heated up, there properties change and the receiver is unable to perform as should. you should take to a service center and let them check for probably some swollen capacitors and replace them. all will be ok.
Posted on Oct 04, 2010
    Genius:
  • 1,478 Answers
The panel on your receiver is bad, you will need to replace the panel on your receiver to fix the problem.
Take care.
Posted on Oct 03, 2010
Coby 26" loses sound after a few minutes, any guess why?
Electronics can fail after they warm up. When they cool down again they start working again. The electronics need replacing, on this TV its cheaper to replace the TV.
Dec 15, 2013 | Coby TF-TV2617 26 in. LCD TV
My sebring convertible1998 wont start when the engine is warm without starting fluid
The automatic choke heater is no longer functioning.Replace it.
Jan 20, 2013 | 1998 Chrysler Sebring
HOW SET TIME TO PIONEER DEH 3450?
turn the unit off. hold the audio/function button until display changes. turn volume knob until clock is displayed. press up/down to change hour then right/left to go to minute then up/down to change. press audio/function to exit. turn back on.
Jun 18, 2010 | Pioneer DEH-P2900MP CD Receiver...
My freezer will freeze for about 2weeks then it starts to get warm when I turn it off for about 6hrs it will refreeze
It sounds to me like the defrost isn't working somewhere.It freezes for 2 weeks until the evaporator coil freezes over and you lose your airflow, hence, your cooling. Then when you shut the unit off for 6 hours it thaws out enough to get you cooling again for 2 weeks.Check your defrost timer and see if it is going into defrost and if your defrost elements are good. Both will be located on top of the unit. Good luck!
Nov 12, 2009 | True 23 cu. ft. / 651 liter Commercial...
After playing my AVR-2802 Denon a while approx 3-4 hrs the sound output juts turns off, after letting it cool down a while it will resume playing ok , then repeats the cycle of loss of audio output.
Seems to be a heat related issue, when it " cools down " awhile it resumes audio output? Be sure you are allowing air circulation around the receiver, I am note sure but I do not think Denons have inboard fans, you could try a ciculating air fan on the unit after playing it for a couple of hours if the receiver feels hot.
Jan 30, 2009 | Denon AVR-2802
Loss spark
Hi
You need to replace the coil but first try to change the sparkplug and see what is happening.
best regards savumihai71
Jan 13, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Vr-309 starts to clip after 10-15 min
This is a case of one or more transistors breaking down when heated. This can be found usually by using freeze spray to cool down one transistor at a time until the problem clears up. You can narrow this down a bit by determining whether this "noise" is effecgted by the volume control or not. Also, does the problem show up faster when the unit plays louder?
Dan
Aug 29, 2008 | Kenwood VR-309
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
Kenwood VR-605 Receiver Logo
41 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
